December 26, 2024 at 8:36 am
ankit.ghosh
SubscriberA noise analysis is to be conducted within the engine room of a small craft, where the air inside the engine room is modeled using solid elements for a purely acoustic analysis. Given that the room is enclosed by steel, an impedance boundary condition is applied to all exposed surfaces. In order to define an impedance boundary in ANSYS, both resistive and reactive components are required. However, there are no suitable resources available to calculate these components. The calculations we have conducted are based on the fundamental principles of acoustic theory. Could you kindly verify and correct them?
Also, guide on " How can I verify and validate the results of my acoustic analysis? Are there any resources available to help perform hand calculations?"
Medium 1 - air
Density of air
ρa
1.225
kg/m3
Speed of sound in air
Ca
330
m/s
Impedance of Air
Za = ρa * Ca
404.25
kg/m2s
Medium 2 - steel
Density of steel
ρs
7750
kg/m3
Speed of sound in steel
Cs
5000
m/s
Impedance of steel
Zs = ρ* Cs
38750000
kg/m2s
Absorption coefficient
α
0.66
For steel
Reflection
R
0.9999
Transmission
T
4.17282E-05
Resistive Component
Zr = Zs / α
58712121.21
kg/m2s
58.712
kg/mm2s
Reactive Component
Za
404.25
kg/m2s
0.00040425
kg/mm2s
January 14, 2025 at 3:29 pm
Federico
Ansys EmployeeHello,
results shown in yellow appear correct to me, except Transmission which differs by a factor of 2 from my results
Z = rho*cR = (Z1-Z2)/(Z1+Z2)
T = 2Z1/(Z1+Z2)
5694
1891
1419
