Velocity, velocity curl and vorticity in post cfd
    • Luca Capitelli
      Hi everyone, I just want to ask the difference between vorticity, velocity curl and velocity in post cfd and which one I may use to show von karman flow. Thanks!
    • Sunil Lilhare
      Hello, Velocity is a vector quantity which represents the rate of change of position of an object with respect to time. Vorticity is a curl of velocity vector. Velocity Curl represents the rigid body rotation part of velocity gradient near a given point. For further information, search using the keywords on internet. To visualize the Von Karman Flow you can make use of Vorticity contour in CFD Post.
  • The topic ‘Velocity, velocity curl and vorticity in post cfd’ is closed to new replies.
