Velocity Boundary Conditions
    • krany3
      What is the difference between swirl velocity and swirl angular velocity in Fluent terms? The Fluent user manual defines them differently. When I gave the values for both swirl(tangential) velocity and angular velocity, the swirl number got doubled. Technically, they should be same. How are they defined in Fluent? Can anyone explain?
    • DrAmine
      Refer to setting Angular Velocity from Fluent User's Guide. The swirl velocity due to your input of angular velocity will be added to the tangential component on top.
      A.
    • krany3
      I got that. But, how is Fluent differentiating Tangential and Angular velocities! They both are dependent on each other.
    • Karthik Remella
      Administrator
      Here is the snip from the Fluent Users guide.
      I hope these definitions bring some more clarity.
      Thank you.
      Best Regards,
      Karthik
  • The topic ‘Velocity Boundary Conditions’ is closed to new replies.
