September 16, 2017 at 11:06 am
bwide
SubscriberHi Everyone,
I'm trying to write a VBScript for Ansys q3d extractor .I have a DXF file that I wanted to import it into Ansys Q3D extractor, each time this file is changed in terms of number of conds
for example: file1
when I import it into the Ansys Q3d extractor software I got 69 cond
file 2
when I import it into Q3d extractor I got 72 cond
so I would like to know how to merge the objects that intersect automatically because each time the number of objects changes from one file to another.
That's what I want regardless of the number of objects
file 3)
 here is the code that I did for a single file but I want it to automatically detect and test the conds that intersect and merge them since I have several different DXF files haven't the same number of conds.
Thank you. Help me please
November 23, 2017 at 12:32 am
sv1437
SubscriberHi bwide,
 Instead of using a script to do this. Try the below procedure:
 1) Select all the objects and unite them. Now they will be shown as single object in the Modeler tree.
 2) Now select the object and select the menu item Modeler > Boolean > Separate bodies.
 Let me know if you have any questions.
-sv
- The topic ‘VBScripting in Ansys Q3D extractor’ is closed to new replies.
5774
