LS Dyna
LS Dyna
Variable to refer to current time in user defined function
    • marcansyl
      Hi all,
      I am currently defining a user-defined function using Beam in Solid. I want to refer to the current time in my function ? What is the global variable used by LS Dyna for the time. My analysis is run for a time range between 0 and 400, and my timestep is 1. This means I will have 401 different times for the function to be called. And What I want to know is how to call the current time each time the function is called. is it "t" ? "time" ? or ...?
      Thanks,
      Marc
    • Andreas Koutras
      Hi Marc, add the following line to confirm that the current time is printed in the terminal screen. Let me know if this works.
      print(time);
    • marcansyl
      Thanks,
      I still cannot use the time as condition in if in my code.
      what I want is to have for instance : if (time>200) {shear=0;}
      when I do that, it gives me shear = 0 for all time between 0 and 400.
      Marc
    • Andreas Koutras
      Hi Marc, check your function with a simple model. What happens to "shear" when time<200? The "time" variable works . Take a look at the sample function below. It will be much more challenging to implement a model in the umat package.
      *DEFINE_FUNCTION
      $#fidheading
      99
      $#function
      float force(float slip,float leng, float *stiff)
      float force;
      if (time>5.e-4) {force=0.1;}
      print(time);
      print(force);
      *stiff=100000.0;
      return force;
  • The topic ‘Variable to refer to current time in user defined function’ is closed to new replies.
