March 18, 2022 at 7:36 pm
sahua1
SubscriberHi ,
I have to use variable current in my EM transient simulation . Currently I am applying the variable current as a data set in my simulation. But, now I want to add a circuit with inductance and resistance. While the external circuit provides those option , but I can only apply the current sources available. Is it possible to add a variable current source in the circuit , just like the data set in Maxwell.
Thanks ,
Ashish
March 24, 2022 at 1:10 amNavya Chode
You can use Piecewise Linear Current Source in the component library>sources for this purpose.
Similarly, you have a Piece Wise Linear Voltage Source also.
Regards Navya
March 28, 2022 at 8:06 pmsahua1
SubscriberThanks a lot Navya. I got it now. This discussion can be closed.
Viewing 2 reply threads- The topic ‘Variable current in Ansys Maxwell external circuit’ is closed to new replies.
6765
1330
1127
