variable cross section in Beam
    • ciema
      Hello can anyone inform me if there is possible to create variable cross section beam in ANSYS Workbench?
      I mean i want to define two cross sections, connect them and create beam not a solid.
      Is there a solution for this problem or we can't do that in workbench?
      If you have two line bodies, each can have their own cross section. The line bodies have vertices that are at the same coordinates. In DM, you create a Multibody part by selecting the two line bodies and Form New Part, or in SC, you use the Share button on the Prepare tab. Then in Mechanical, there will be a single node that connects the beam elements on either side that have different cross-sections.
    • ciema
      Thanks for help, but is there a way to add script with commands from APDL and connect it to simple line body in workbench, and get proper solution basing on that commands and variable section from APDL?
      I expect that is possible but not something I know how to do.
    • ciema
      Thats all i ve got, but it creates only one cross section...
      /PREP7
      E=2e11
      ET,1,BEAM188
      MP,EX,all,E
       /PREP7
      !KEYOPT,1,12,0
      SECTYPE,   1, BEAM, RECT, big, 0
      !SECNUM,1
      !LATT,1,1,1,,,,1
      SECOFFSET, CENT
      SECDATA,7.8,1.4,0,0,0,0,0,0,0,0,0,0
      SECTYPE,   2, BEAM, RECT, small, 0
      !SECNUM,2
      !LATT,1,1,1,,,,2
      SECOFFSET, CENT
      SECDATA,0.9,0.2,0,0,0,0,0,0,0,0,0,0
      SECTYPE,3,TAPER,,tap
      !SECNUM,3
      !LATT,1,1,1,,,,3
      SECDATA,   1,0,0,0,
      SECDATA,   2,1,0,0,
      !SECTYPE,,BEAM,ASEC
      K,1,0,0,0,
      K,2,1,0,0,
      LSTR,       1,       2
      FLST,5,1,4,ORDE,1
      FITEM,5,1
      CM,_Y,LINE
      LSEL, , , ,P51X
      CM,_Y1,LINE
      CMSEL,,_Y
      LESIZE,_Y1,0.1, ,10, , , , ,1
      TYPE,   1
      MAT,       1
      REAL,
      ESYS,       0
      SECNUM,   3
      LMESH,       1
      FLST,2,1,3,ORDE,1
      FITEM,2,1
      /GO
      DK,P51X, , , ,0,ALL, , , , , ,
      FLST,2,1,3,ORDE,1
      FITEM,2,2
      /GO
      FK,P51X,FY,-1000
      FINISH
      /SOL
      SOLVE
Viewing 4 reply threads
  • The topic ‘variable cross section in Beam’ is closed to new replies.
