May 23, 2024 at 10:26 am
2842533H
SubscriberHi,
I was using lumerical 2022 R2.4 and recently updated it to 2023 R2.3. After that, it crashes when I open a new or old project in varFDTD. Closes the project without saving. I tried to remove all folders and install old and new versions, including 2022, 2023 and 2024. But the problem still continues. Can you please help me, I couldn't find any cases like that online. I am a commercial customer so you can also reach me via email.
Best Wishes
May 27, 2024 at 10:05 am
2842533H
SubscriberI followed clean reinstall procedure in lumerical website an installed 2024 version. But the problem still continues. Has anyone faced with this problem before? -
May 27, 2024 at 4:36 pm
Lito
Ansys EmployeeHi Ahmet,Â
Sorry to hear that you are having issues with Lumerical varFDTD.Â
- Reboot your computer,
- Remove the Lumerical product preference.ini files from your user's folder in your computer,
- Open the Optics Launcher,Â
- Click on "New Project" for varFDTD or the solver which you have the license for.Â
- Or open MODE directly from the "Start Menu".
- Should the issue persist, please send the Ansys client licensing log files from your computer.
- Check/update to the latest Display Adapter drivers from the manufacturer.Â
- Check the Windows > Event Viewer > Application & System logs for any errors at the time the crash happens on your computer.Â
- The topic ‘varFDTD crashes when opened’ is closed to new replies.
