TAGGED: 2022-r1, ansys-mechanical, fatigue, fatigue-tool, surface-coating
May 16, 2022 at 7:41 am
yhamurisci
SubscriberHello,
Is there any way to scoping results from surface coating for fatigue calculations?
For result items of fatigue such as life, damage, safety factor, scoping methods are geometry and named selections only as far as I see in 2022R1.
May 16, 2022 at 10:50 amAniket
Forum ModeratorIt is not currently possible to select the surface coating as result item for fatigue calculations, please see if APDL way helps you to do the same:
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/ans_arch/Hlp_G_STR12_2.html
-Aniket
May 17, 2022 at 5:08 amyhamurisci
SubscriberThank you.
Viewing 2 reply threads- The topic ‘Utilization of surface coating results for fatigue calculations’ is closed to new replies.
1997
897
599
591
418
