TAGGED: eigenmode, export, export-result, exporteigenmodes, extract-results
November 1, 2021 at 5:22 pm
mwhitby
SubscriberI did FDE analysis for my simulation. Then I calculated the modes and got a data table inside the Eigensolver Analysis Tab called Mode List. From this data I would like to extract the loss and the TE polarization fraction. Ideally I would like to be able to extract these values and assign them to variable names, however it would also work if I can export the full data table to a .csv file. Is there any way to do this in the script?
Currently in the script I have:
run;
findmodes;
What I would like to do right after this is have something like:
mode1_TE_frac = put command here to extract the TE polarization fraction for mode 1
Is this possible? I tried using the getdata(); command but it didn't work out.
November 1, 2021 at 10:35 pmGuilin Sun
Ansys Employeeyes, we have script for you. Please refer the other post: How to extract values from Mode List data in Eigensolver Analysis ÔÇö Ansys Learning Forum
Viewing 1 reply thread- The topic ‘Using Script to Extract Loss and TE fraction from Mode List after Calculating Modes’ is closed to new replies.
4633
1535
1386
1225
