May 7, 2025 at 12:59 am
Shyam Prasad V Atri
SubscriberHello
I am looking at the tutorial 23 which explains how to set up the modules and file paths so on for windows. Can anyone please explain how to do the same for linux?
I do not see any instructions for the same for linux. What version of compiler to use so on etc.Â
If anyone would please give detailed instructions as given for tutorial 23 it would be extremely helpful
where should I define the environment variable to place the compiled files
May 7, 2025 at 12:29 pm
Jackson Gomes
Ansys EmployeeHi Shyam.
All information you need is located in the Tutorial 23 -Â Chapter : 23.1.5. Working Environment Setup for Linux 64-bit.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
1495
1386
1209
