December 2, 2024 at 8:30 am
uygar.kartal
SubscriberHello guys,
Currently, I am running a thermal analysis in Ansys Discovery, and I want to place a sensor at the center of a sphere to view its time-dependent temperature graph. Is there a way to do that?
I would appreciate it if you could help. -
December 2, 2024 at 11:13 am
subashni.satish
Forum ModeratorHello,
You can create a point at the center of the Sphere and create a custom monitor at the point location.
To create the point, you can use the 3D point tool under Design Tab > Create,
Check out the below Knowledge article for tips on creating monitors.
Discovery Quick Tip- Monitors on Construction Geometry | Ansys Knowledge
December 2, 2024 at 2:33 pm
uygar.kartal
SubscriberHello,
Thank you so much for your help that was all I need. 😀
February 12, 2025 at 4:19 am
bradleyearnest006
SubscriberÂ
Your assistance was just what I needed, so thank you very much and you can try Doodle Jump. 😀
6845
1343
1152
