Photonics
Photonics
Using multiple versions of Lumerical on the same machine
    • Lito
      Notes: Installing multiple versions of Lumerical on the same computer is not recommended. However, it can occasionally be useful, such as when confirming that the old and new versions give the same results.
      Process: When installing the newer release of Lumerical on your computer, select "Not to Uninstall" or "Not to remove previous version" when prompted during the installation process.
Viewing 0 reply threads
  • The topic ‘Using multiple versions of Lumerical on the same machine’ is closed to new replies.
