July 5, 2023 at 3:29 pm
July 6, 2023 at 12:36 pm
Ashish Khemka
Forum ModeratorHi,
Please see if the following link helps you: LSDYNA Basics I — Welcome to LS-DYNA Examples (ansys.com)
Ashish Khemka
July 6, 2023 at 2:30 pm
Jim Day
Ansys EmployeeThere's no switch to make the explicit solver linear in the same sense that implicit can be made linear. Explicit always considers finite displacements and rotations. That said, if the material is *MAT_ELASTIC and there is no contact and the deformation is small, the explicit solution should agree with a linear implicit solution. I would recommend double precision however.
- The topic ‘Using linear solution method for explicit solver in LS-DYNA’ is closed to new replies.
