August 30, 2023 at 2:13 pm
Aneela Banda
SubscriberWe have current license server is live on a network that is not accessible by our HPC cluster. Can we know how we can get a file based license from the existing licensing and use it on our HPC cluster which has Ansys Fluent 2021R1 configured and we are using RHEL 8.5 . Can we also know if we can use 2020 's version of ansys fluent license server for 2021 R1 on HPC?
August 31, 2023 at 7:26 pm
George Karnos
Ansys EmployeeI do not believe this is a licensing issue, however if you want to switch where your license exists, You can have your License Administrator or Ansys Support Coordinator rehost the license key to another machine. You can also reach out to your ANSYS Account Manager.
The Error in the pic you posted look to be prerequiites missing or incompatible:
You can also search the form forÂEVP_KDF_ctrl
Other ideas may be listed.
See Post: /forum/forums/topic/ansys-installation-on-centos-8-0/
Have you confirmed all prerequisites have been installed?
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_sysprereqs.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_addlhwswreqt.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_thirdparty.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_platformdetails.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_platform_libraries.html -
October 10, 2023 at 3:24 pm
October 10, 2023 at 4:36 pm
George Karnos
Ansys EmployeeCheck the firewall.
On the license server machine, verify that the following are added to exceptions:
lmgrd.exe
ansyslmd.exe
ansysli_server.exe
https://www.youtube.com/watch?v=XIh47MZG__A&list=PL0lZXwHtV6OkRCk-_jQqtA0sTNgTWYB-i&index=15
This error is usually due to the ansyslmd being bloecked. -
October 10, 2023 at 4:42 pm
Aneela Banda
Subscriberwhen i do telnet its getting connected right
October 10, 2023 at 4:49 pm
George Karnos
Ansys EmployeeThrough port 1055 it is.
ansyslmd uses a different port.
October 10, 2023 at 4:51 pm
Aneela Banda
Subscriberok by adding those exceptions in the machine where license server is present and running the fluent in my machine works right? or should i have to add any other configuration on my system?
October 10, 2023 at 4:53 pm
George Karnos
Ansys EmployeeYes, it should run.
That error usually mean ansyslmd is being blocked on the license server.
- The topic ‘Using licensing server’ is closed to new replies.
4678
1565
1386
1241
