December 10, 2019 at 7:44 pm
DavidB7
SubscriberHello,Â
I am currently solving the case of forced convection across a heated horizontal cylinder (with constant surface temperature conditions). I know the equation to calculate the local Nu= - dT/dr (which is the temperature derivative along the normal vector to the cylinder surface).
I couldn't calculate the temperature derivative by using the expression tab in CFD-Post, i put the expression as follows: "Temperature.Gradient R @cylinder wall "
but it gives me the following error: "The following unrecognized name was referenced: Temperature.Gradient R"
P.S. i identified another variable "R" and its expression is sqrt(X^2 +Y^2) and i created a polyline at the cylinder surface and named it "cylinder wall"
Thank you!
December 11, 2019 at 10:56 am
Forum ModeratorTry getting the output of Temperature.Gradient @cylinder wall and see what happens. As a more general comment, I mostly use _ and never a "space" when setting up models, expressions etc. Probably not needed any more, but was critical when I started using the software: it does mean I miss some issues!Â
December 11, 2019 at 3:17 pm
DavidB7
SubscriberHello Rwoolhou,Â
Thank you for replying!
Unfortunately, I tried this expression as well and got this error: "The following unrecognised name was referenced: Temperature.Gradient." -
December 11, 2019 at 4:26 pm
Forum ModeratorIf you've come from Fluent have a look at Custom Field Functions and also the Thermal & Wall post-processing options. Check Temperature.Gradient exists too: it may not be defined in Post.Â
December 18, 2019 at 2:49 am
DavidB7
SubscriberHello Rwoolhou, i checked and i couldn't find it. However, i created an expression to calculate the local nusselt number and it worked fine for the steady state linear conditions.Â
I wanted to ask another question; can i ask here or should i make another post?Â
Thank you for your help! -
December 18, 2019 at 11:58 am
Forum ModeratorAnother thread please: makes it easier to track.Â
December 24, 2020 at 1:02 pm
MahmoudHI
SubscriberHello David,ni would like to ask you about the expression you used in finding the local Nusselt No. nyour clarification will be highly appreciated. Since I'm currently working on a similar problem where I have a fluid flowing into a horizontal tube with a uniform heat flux applied to the tube wall. n
- The topic ‘Using CFD-Post to calculate the Local Nusselt number on the surface of a horizontal cylinder’ is closed to new replies.
6600
1311
