July 8, 2020 at 4:53 pm
andrewe
SubscriberHi, I am looking to correctly create a material with the data shown in the table. The properties are different in the machine direction (MD) and transverse direction (TD). The material is a thin film, i would also like to orientate the properties correctly in the model.
Also in thmmodel I am using carbon fibre rods (which support the film) at the top and left edge
My question: How do ensure the anisotropic material properties are correctly orientated in the models parts?
I need the MD to be in say the X direction of the thin film membrane. For the carbon rods I need the anisotropic properties in the correct directions. I'd be grateful for any advice or guidance, thanks.
July 9, 2020 at 12:17 pm
Karthik Remella
AdministratorAre you using Ansys Mechanical for this?
Thanks
Karthik
July 9, 2020 at 12:20 pm
July 13, 2020 at 3:08 pm
Aniket Chavan
Forum Moderator -
July 13, 2020 at 3:19 pm
andrewe
SubscriberHi, I only have access to the student portal.
July 13, 2020 at 5:17 pm
Aniket Chavan
Forum ModeratorPlease check my signature, it explains how to access the ansys help links.
Basically you need to use element orientations.
-Aniket
How to show full resolution image
How to use Google to search within Ansys Student Community
November 23, 2023 at 5:07 pm
jordan Kemguimatio kenfack
SubscriberHello,
I have two questions please;
1. how can i define a 45° oriented youngs modulus of a material ? is it possible with the orthotropic model definition ? Since with orthotropic modelling we just have orthogonal axes (90°) --> I have the youngs modulus in longitudinale direction, transverse direction and oblige(45°) direction. I can input the longitudinale direction(x) and transverse direction(y,z) what about the 45° ?
2. can i assigned 2 material property in ansys which are reference to two different coordinate system? ( exemple i wish to define two local coordinates system with different orientations, then assigne orthotropic properties to each coordinates systems)
- The topic ‘Using anisotropic materials’ is closed to new replies.
3977
1461
1272
1124
