October 17, 2018 at 10:24 am
jhniat
SubscriberI am trying to create charts of a user defined result vs distance along a concrete RC beam. I am particularly interested in the normal and shear stresses at the interface between two concrete layers. I have defined a path spanning the length of my beam which runs along the centreline of the top face of the beam. I have turned on the mesh and snapped it to the mesh nodes. I want to setup a user defined result for the ratio of normal stress to shear stress but for some reason the normal and shear stress results, when scoped to a path will not come up with the identifier field required to do this.
Can someone please help me with this?
If not is there some way I can manually export the tabulated data for both the normal and shear stresses as functions of position x along the beam to be configured and plotted externally of Ansys?
October 17, 2018 at 10:41 am
Rohith Patchigolla
Ansys Employee -
October 17, 2018 at 12:31 pm
jhniat
SubscriberThank you very much. I was not aware that preset 'identifiers' for normal and shear stress existed.
October 17, 2018 at 1:45 pm
Rohith Patchigolla
- The topic ‘User defined results and charts for a path using identifiers’ is closed to new replies.
6379
