Electronics
Electronics
User defined Primitve error for RMxprt when using StepMCore: RingLength must be larger than 0.
    • Magnet_man
      I am trying to use the RMxprt to make a simple stepper motor, but when i change the "InfoCore" property to 3 to select magnets, i get an error that "User Defined Primitive : RingLength must be larger than 0."
      I simply cannot figure out how to edit this RingLength parameter, as i have no idea where it's located..
      I am using ansys electronics desktop 2020 R1, and i'm using the version 19.4 of the StepMCore, updated 01-01-2019.
      Hope anyone can help!
    • Navya Chode
      Can you share the screenshot of the UDP window with the values you entered?
      Please use the image option and not the Attachment option while sharing the screenshots.
      Regards Navya
    • Magnet_man
      Here's my parameters, and the error message i receive. Cheers!
  • The topic ‘User defined Primitve error for RMxprt when using StepMCore: RingLength must be larger than 0.’ is closed to new replies.
