March 11, 2024 at 2:53 pm
yu272
SubscriberHi all,
I am simulating an anisotropic hyperelastic material using AHYPER exponential model, and implementing APDL commands in workbench simulation. The AHYPER constant is obtained by fitting experimental data. However, I cannot fit compression data well which causes the material model to be stiffer than expected.Â
Is there any method for workbench simulation to is to apply multiple material models for one object? such as AHYPER for tension and another softer material model for compression by using APDL command?Â
Sincerely,
Eric
March 12, 2024 at 9:42 am
Sahil Sura
Ansys EmployeeHi Eric,
Please check the following link to explore different nonlinear material models offered by Ansys -Â Â https://ansyshelp.ansys.com/Views/Secured/corp/v232/en/ans_str/Hlp_G_STR8_3.htmlConsidering the complexity of the material model, you might achieve this by running separate simulations for tension and compression, each with its material model, and then combining the results.
Please check the following references for more insights -Â
/forum/forums/topic/using-experimental-material-properties-in-structural/Hope this helps!
Thanks,
Sahil
For more exciting courses and certifications, hit this link: Ansys Innovation Courses | Ansys Innovation Space
If you are not able to open the links, refer to this forum discussion:Â How to access the ANSYS Online Help
March 12, 2024 at 5:29 pm
yu272
SubscriberHi Sahil,
Thank you for the information! To be more specific on my question, I will need this material model to do FSI simulation, and the solid will need both proper tension and compression. Therefore, it would be good if we could use some APDL command to control if the strain is negative, it can use a different model. Is this possible?
Sincerely,
Eric
- The topic ‘User-defined hyperelastic material model for workbench structural simulation’ is closed to new replies.
5799
