User defined function and plot for varying dimension of a geometry using ANSYS fluent.
    • mrmogan
      Sir
      I want to vary the diameter ( diameter: 3cm, 4cm, 5cm ) of pipe in which fluid Flows using fluent.
      How to write udf or parameter in Fluent for getting solution for different diameter ?
      Also how to plot graph while taking different diameters in x axis and any other variable in y axis ?
      Please guide me to do this using fluent ?
      mrmogan
    • pgl
      mrmorgan,
      Please take a look at our online help documentation for ANSYS Fluent. Go to Help > ANSYS Workbench Help in the Workbench Menu.
      Chapter 2 of the Fluent Section covers Parametric Analysis, i.e. You make the pipe diameter a parameter.
  • The topic ‘User defined function and plot for varying dimension of a geometry using ANSYS fluent.’ is closed to new replies.
