June 21, 2026 at 7:13 am
1595304812
SubscriberI am trying to use the SALE method to simulate the penetration of a spherical high-pressure gas cylinder by a projectile. However, I encountered the following error:
“forrtl:severe (157): program exception-access violation”
The simulation behaves normally when the projectile enters the cylinder, and no leakage occurs at that stage. However, when the projectile exits from inside the cylinder, the calculation crashes with the above exception as soon as the projectile just touches, or is about to touch, the inner surface of the cylinder on the exit side。
The model details are as follows:The model is a 1/4 symmetric model, using the mm-ton-N-s unit system. The projectile consists of an aluminum core and a copper jacket. The cylinder body has two layers. The meshes of the two cylinder parts share common nodes at the interface. Both cylinder layers are made of titanium alloy.
All solid parts are modeled with solid elements and use *MAT_JOHNSON_COOK together with *EOS_GRUNEISEN. The solid mesh size is 0.5 mm.The gas is modeled using *MAT_NULL with*EOS_LINEAR_POLYNOMIAL.
I used *ALE_STRUCTURED_MESH_VOLUME_FILLING to initialize the entire S-ALE background mesh as “airout”,with:RO=1.225e-12,C4=0.4,E0=0.25 which corresponds to a pressure of about 0.1 MPa.The region inside the cylinder, bounded by the inner surface of the cylinder, was initialized as “airin”, with:RO=1.225e-10,C4=0.4, E0=25 which corresponds to a pressure of about 10 MPa.
I used three *ALE_STRUCTURED_FSI definitions:
1. coupling between “airin”. and the outer cylinder layer;
2. coupling between “airin”. and the inner cylinder layer;
3. coupling between the projectile and “airin”.
For the first two FSI definitions, the “PFAC” value is defined through a user-defined curve for leakage control. For the projectile–airin coupling, “PFAC” is kept as the default value of 0.1.
I also tried a penetration-only case without the fluid domain, and that model could reach normal termination.
June 21, 2026 at 7:14 am
1595304812
Subscriber*KEYWORD
*TITLE
$# title
LS-DYNA keyword deck by LS-PrePost
*CONTROL_ALE
$# dct nadv meth afac bfac cfac dfac efac
-1 1 -2 -1.0 0.0 0.0 0.0 0.0
$# start end aafac vfact prit ebc pref nsidebc
0.01.00000E20 0.01.00000E-6 0 0 0.0 0
$# ncpl nbkt imascl checkr beamin mmgpref pdifmx dtmufac
1 50 0 0.0 0.0 0 0.0 0.0
$# optimpp ialedr bndflx minmas
0 0 01.00000E-5
*CONTROL_CONTACT
$# slsfac rwpnal islchk shlthk penopt thkchg orien enmass
0.1 0.0 1 0 1 0 1 0
$# usrstr usrfrc nsbcs interm xpene ssthk ecdt tiedprj
0 0 0 0 4.0 0 0 0
*CONTROL_ENERGY
$# hgen rwen slnten rylen irgen maten drlen disen
2 2 2 2 2 1 1 1
*CONTROL_TERMINATION
$# endtim endcyc dtmin endeng endmas nosol
2.00000E-4 0 0.0 0.01.000000E8 0
*CONTROL_TIMESTEP
$# dtinit tssfac isdo tslimt dt2ms lctm erode ms1st
0.0 0.67 0 0.0 0.0 0 0 0
*DATABASE_GLSTAT
$# dt binary lcur ioopt
1.00000E-6 0 0 1
*DATABASE_MATSUM
1.00000E-6 0 0 1
*DATABASE_RCFORC
1.00000E-6 0 0 1
*DATABASE_SPCFORC
1.00000E-6 0 0 1
*DATABASE_BINARY_D3PLOT
$# dt lcdt beam npltc psetid
1.00000E-6 0 0 0 0
*DATABASE_BINARY_FSIFOR
$# dt lcdt beam npltc psetid cid
1.00000E-6 0 0 0 0 0
*DATABASE_EXTENT_BINARY
$# neiph neips maxint strflg sigflg epsflg rltflg engflg
10 0 3 0 1 1 1 1
$# cmpflg ieverp beamip dcomp shge stssz n3thdt ialemat
0 0 0 1 1 1 2 1
$# nintsld pkp_sen sclp hydro msscl therm intout nodout
0 0 1.0 0 0 0
$# dtdt resplt neipb quadsld cubsld deleres
0 0 0 0 0 0
*DATABASE_FORMAT
$# iform ibinary
0 0
*DATABASE_FSI
$# dtout binary
1.00000E-6 1
$#dbfsi_id sid sidtype swid convid ndsetid cid
1 22 1 0 0 0 0
2 21 1 0 0 0 0
*BOUNDARY_SALE_MESH_FACE
$# bctype mshid negx posx negy posy negz posz
SYM 1 0 1 0 0 1 0
NONREFL 1 0 0 1 1 1 0
*BOUNDARY_SPC_SET
$# nsid cid dofx dofy dofz dofrx dofry dofrz
1 0 1 0 0 0 1 1
*SET_NODE_LIST_TITLE
X
$# sid da1 da2 da3 da4 solver its -
1 0.0 0.0 0.0 0.0MECH 1
*BOUNDARY_SPC_SET_ID
$# id heading
2
2 0 0 0 1 1 1 0
Y
*CONTACT_TIED_SURFACE_TO_SURFACE
$# cid title
$# surfa surfb surfatyp surfbtyp saboxid sbboxid sapr sbpr
1 2 0 0 0 0 0 1
$# fs fd dc vc vdc penchk bt dt
0.0 0.0 0.0 0.0 0.0 0 0.01.00000E20
$# sfsa sfsb sast sbst sfsat sfsbt fsf vsf
1.0 1.0 0.0 0.0 1.0 1.0 1.0 1.0
*SET_SEGMENT_TITLE
JACKET_INSIDE
1 0.0 0.0 0.0 0.0MECH 0
$# n1 n2 n3 n4 a1 a2 a3 a4
*SET_SEGMENT_TITLE
CORE_OUTSIDE
2 0.0 0.0 0.0 0.0MECH 0
*CONTACT_ERODING_SURFACE_TO_SURFACE
$# cid title
3 1 2 2 0 0 1 1
0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
$# isym erosop iadj
1 1 1
$# soft sofscl lcidab maxpar sbopt depth bsort frcfrq
2 0.1 0 1.025 2 2 0 1
*SET_PART_LIST_TITLE
CONTAINER
3 0.0 0.0 0.0 0.0MECH
$# pid1 pid2 pid3 pid4 pid5 pid6 pid7 pid8
1 2 0 0 0 0 0 0
BULLET
3 4 0 0 0 0 0 0
*HOURGLASS
$# hgid ihq qm ibq q1 q2 qb/vdc qw
1 6 0.1 0 0.0 0.0 0.0 0.0
*MAT_ADD_EROSION_TITLE
cu
$# mid excl mxpres mneps effeps voleps numfip ncs
4 0.0 0.0 0.0 0.3 0.0 1.0 1.0
$# mnpres sigp1 sigvm mxeps epssh sigth impulse failtm
0.0 0.0 0.0 0.3 0.0 0.0 0.0 0.0
al
3 0.0 0.0 0.0 0.0 0.0 1.0 1.0
0.0 0.0 0.0 0.5 0.0 0.0 0.0 0.0
ti
5 0.0 0.0 0.0 0.0 0.0 1.0 1.0
0.0 0.0 0.0 0.6 0.0 0.0 0.0 0.0
*MAT_NULL_TITLE
AIRIN(10Mpa)
$# mid ro pc mu terod cerod ym pr
11.2250E-10 0.0 0.0 0.0 0.0 0.0 0.0
*MAT_NULL_TITLE
AIROUT(0.1Mpa)
21.2250E-12 0.0 0.0 0.0 0.0 0.0 0.0
*MAT_JOHNSON_COOK_TITLE
AL
$# mid ro g e pr dtf vp rateop
32.80000E-9 26700.0 63950.0 0.33 0.0 0.0 0.0
$# a b n c m tm tr epso
602.5 732.1 0.753 0.014 1.015 878.0 293.0 1.0
$# cp pc spall it d1/beta d2/wc d3/dc d4/gamma
8.750000E8 0.0 3.0 0.0 0.22 0.12 2.8 0.0
$# d5c2/p/xnp/d erod efmin numint k eps1 dmodel
0.0 0.0 1.0 0.0 0.0 0.0 0.0 0.0
CU
48.96000E-9 13700.0 117000.0 0.34 0.0 0.0 0.0
90.0 292.0 0.31 0.025 1.09 1356.0 293.0 1.0
3.830000E8 0.0 3.0 0.0 0.54 0.0 0.0 0.0
0.0 0.0 1.01.00000E-6 0.0 0.0 0.0 0.0
Ti
54.40000E-9 419000.0 114000.0 0.33 0.0 0.0 0.0
1098.0 1092.0 0.93 0.014 1.115 1878.0 293.0 1.0
5.600000E8 0.0 3.0 0.0 -0.09 0.25 -0.5 0.014
3.87 0.0 1.0 0.0 0.0 0.0 0.0 0.0
*INITIAL_VOLUME_FRACTION_GEOMETRY
$# fmsid fmidtyp bammg ntrace
10 1 1 3
$# conttyp fillopt fammg vx vy vz - -
6 0 2 0.0 0.0 0.0
$# x0 y0 z0 r0 - - - -
0.0 0.0 0.0 104.0
*INITIAL_VELOCITY_GENERATION
$# id styp omega vx vy vz ivatn icid
1 1 0.0 0.0 -800000.0 0.0 0 0
$# xc yc zc nx ny nz phase irigid
0.0 0.0 0.0 0.0 0.0 0.0 0 0
*DEFINE_CURVE
$# lcid sidr sfa sfo offa offo dattyp lcint
1 0 1.0 1.0 0.0 0.0 0 0
$# a1 o1
0.0 0.0
0.2 150.0
$# mshid dpid nbid ebid - - - tdeath
1 10 0 0 1.00000E16
$# cpidx cpidy cpidz nid0 lcsid
1 2 3 0 0
*ALE_STRUCTURED_MESH_CONTROL_POINTS
$# cpid - icase sfo - offo
1 0 1.0 0.0
$# n x ratio/xl
1 -120.0 0.0
61 0.0 0.0
2 0 1.0 0.0
$# n x ratio/xl
1 -120.0 0.0
141 160.0 0.0
3 0 1.0 0.0
$# n x ratio/xl
1 0.0 0.0
61 120.0 0.0
*ALE_MULTI-MATERIAL_GROUP_PART
$# pid
21
22
*ALE_STRUCTURED_FSI
$# lstrsid alesid lstrstyp alestyp - - - mcoup
2 10 1 1 -2
$# start end pfac fric ilvl flip decay offset
0.01.00000E10 -1 0.0 0 0 0.0 0.0
*ALE_STRUCTURED_FSI
1 10 1 1 -2
*ALE_STRUCTURED_FSI
1 10 0 1 -2
*EOS_LINEAR_POLYNOMIAL_TITLE
AIRIN
$# eosid c0 c1 c2 c3 c4 c5 c6
1 0.0 0.0 0.0 0.0 0.4 0.4 0.0
$# e0 v0
25.0 1.0
*EOS_GRUNEISEN_TITLE
AL
$# eosid c s1 s2 s3 gamma0 a e0
2 5328000 1.388 0.0 0.0 2.0 0.47 0.0
$# v0 - lcid
1.0 0
CU
3 3940000 1.4989 0.0 0.0 2.02 0.0 0.0
$# v0 - lcid
1.0 0
AIROUT
4 0.0 0.0 0.0 0.0 0.4 0.4 0.0
$# e0 v0
0.25 1.0
TI
5 5130000 1.028 0.0 0.0 1.23 0.17 0.0
$# v0 - lcid
1.0 0
*PART
$# title
CONTAINER_OUTSIDE
$# pid secid mid eosid hgid grav adpopt tmid
1 1 5 5 1 0 0 0
*SECTION_SOLID_TITLE
SOLID
$# secid elform aet - - - cohoff gaskett
1 1 0 0.0 0.0
*PART
$# title
CONTAINER_INSIDE
2 1 5 5 1 0 0 0
*PART
$# title
JACKET
3 1 4 3 1 0 0 0
*PART
$# title
CORE
4 1 3 2 1 0 0 0
*PART
$# title
AMMG1(AIROUT)
21 2 2 4 0 0 0 0
SALE
2 11 0 0.0 0.0
*PART
$# title
AMMG2(AIRIN)
22 2 1 1 0 0 0 0
SOLID
1 2 3 4 0 0 0 0
*SET_MULTI_MATERIAL_GROUP_TITLE
AIROUT
$# ammsid
1
$# ammgid1 ammgid2 ammgid3 ammgid4 ammgid5 ammgid6 ammgid7 ammgid8
1 0 0 0 0 0 0 0
AIRIN
$# ammsid
2
2 0 0 0 0 0 0 0
ALE(ALL)
$# ammsid
3
1 2 0 0 0 0 0 0
*END -
June 22, 2026 at 6:24 am
ErKo
Ansys EmployeeHello,
Synopsys employees cannot answer this query. Please wait for other forum members to chime in.
Thanks and Regards,
Erko
June 24, 2026 at 7:22 am
Dennis Chen
SubscriberHello, I am actually thinking about doing something like this over the weekend for my youtube channel (the SALE version of load_blast_enhanced) so I may have a more detailed example later that may be helpful to you. The keyword you shared doesn't let me see any *mesh or *nodes so I cannot see it inside LSPP but if you are willing to share the full input file, my email is zchen6@gatech.edu.
I believe the error message above is not indicative of anything other than that the solver crashed. If there's a potentially useful generic troubleshooting process here, it would be to try to remove certain aspect of the models one by one until you can proceed past this point and narrow down to where the problem is coming from.
6765
1330
1142
