Use of the Ansys APDL function Editor
    • Emilie Stud
      I am using ansys APDL function editor, to apply a function where I need to use the position of the nodes at the initial time, among other variables of my function. I tried to use the writing "{X{TIME=0}" in my function, but then when I want to read the function file it asks me to give the value of the constant value "-X". Does someone know if I am using the correct syntax or how to proceed otherwise ?
    • ErKo
      Hi
      Never used this, but below showns how you write discrete point of "functions" into arrays and tables:
      https://www.ozeninc.com/apdl-arrays-tables-quickreference/
      All the best and hope it helps
      Erik
  • The topic ‘Use of the Ansys APDL function Editor’ is closed to new replies.
