July 23, 2024 at 10:07 am
maja.wolkenstein
SubscriberHi,
I have defined a spring (combin14) in a static structural simulation and I am evaluating the maximum elongation of this spring
The maximum eleongation of that spring is defined as parameter.
Afterwards I would like to use the value of the maximum elongation of the spring as a constraint in a topology optimization
The value of maximum elongation 0,0073334 from the static structural sim is now a response constraint in the topology optimization.
How can I use the parameter from the static sim in topology optimization. What would be the APDL comman to transfer the parameter from one sim to the other. And how can I access the parameter in topo opti.
Generall I would write a input file to retrive the APDL commands but however since elongation is a post result all the outputs are stored in the XML file.
Thanks a lot
Wolke
July 24, 2024 at 1:52 pm
- The topic ‘Use of Parameters (static structural results) as input for topo optimization’ is closed to new replies.
5674
1890
1419
