July 27, 2022 at 7:32 am
Dubey92
SubscriberI am adding source terms in momentum and energy equation. I am using Solidification/Melting in FLUENT. Whenever I use C_R(c,t) and C_LIQF(c.t) in my UDF, the UDF compiles without any error but when I start the simulation, the simulation crashes with mpt:9999 no error. Can someone please tell me about the issue? Any help is appreciated.
July 27, 2022 at 8:20 am
SVV
Ansys EmployeeHi,
Check if UDF has values to be stored in UDM. If yes, please define UDM before running simulation. Details on UDM is available in sectionÂ
3.2.12. User-Defined Memory (UDM) Macros in 3.2. Data Access Macros (ansys.com)
July 27, 2022 at 9:51 am
Dubey92
SubscriberHello Swathi, thanks for your reply. I have allocated enough number of UDMs before running the simulation still it crashes.
July 27, 2022 at 8:25 am
Forum ModeratorRead the top line of the error, mpt:9999 is a process error, but there may be something more useful at the top.Â
July 27, 2022 at 9:52 am
Dubey92
SubscriberHi Robert, thanks for your reply. There are multiple lines showing mpt:9999 and before I can reach the top, FLUENT closes.
July 27, 2022 at 1:09 pm
Forum ModeratorNot sure then. If you post the code there may be something obvious: note staff won't be debugging but we can offer hints and the wider community are able to post more freely (we're covered by export laws).
- The topic ‘Use of C_R(c,t) and C_LIQF(c,t) inside DEFINE_SOURCE’ is closed to new replies.
6625
1311
