May 1, 2024 at 10:05 am
576650550
SubscriberUpon employing Simplorer for circuit simulation, an error occurred whilst importing the SPICE model:
Error 10554 - Unable to link a connection.Model: AD8672_1.GSYNode: 2.24E-3<0>>> Prepare Âbut the SPICE model was obtained from the company’s official website.The issue highlighted that the specified node does not exist. it is merely a statement of this nature:
GSY 99 50 POLY(1) 99 50 2.24E-3 15E-6. just a parameterThe circuit’s operation is capable of yielding results, but outputs are wrong ,the output of the operational amplifier is saturated, yet the voltage amplitude fails to reach the supply voltage of 12 volts.
What could possibly be the issue?
June 5, 2024 at 8:35 pm
HDLI
Ansys EmployeeHello Jingxuan,
   The Twin builder/Simplorer only has Spice compiler type either to Berkeley Spice or PSPICE, not for all the Spice types. You may need to modify the code of the Spice model to make it work. Thanks.
HDLI
- The topic ‘Upon employing Simplorer for circuit simulation, an error occurred whilst import’ is closed to new replies.
