TAGGED: results, static-structural, structural, structure, update
August 3, 2021 at 12:01 pm
dimitri.hamelin
SubscriberAugust 4, 2021 at 1:28 pmAshish Khemka
Can you open the model and check what is the error message indicated in the Solution Information?
Regards Ashish Khemka
August 4, 2021 at 1:41 pmdimitri.hamelin
Subscriber! Thank you for your answer !
Well, this is the problem, I run my calculation, my project closes (Not Workbench, Only Mechanical) and I have nothing in my Solver Output (every flashes are yellow)
The project works when I suppress the second APDL result I have created.
Thank you.
August 6, 2021 at 1:52 pmdimitri.hamelin
Dear here is a new error message that have appeared today.
I made a copy of my "Static Structural" and suppressed the link between my steady state thermal and my static structural only for the solution (position D5).
For my static structural C5, I have suppressed the APDL File results this is why everything is green.
Before the error message when I was opening my model, I had 3 static structural Solutions in my tree on the left, but only Two Static structural blocks in Workbench and two with the same "coordinates" ...
Their names were:
-Static Structural (C5)
-Static Structural 2 (D5)
-Static Structural 3 (D5)
Thank you for your futur answer.
August 9, 2021 at 10:35 amAshish Khemka
Forum ModeratorHi It may be that system is corrupted. What if you try running the model in a new setup?
August 12, 2021 at 8:27 amdimitri.hamelin
I gave up and I restarted all my project copying and pasting my APDL Command, I simplified it and used Excel to do my calculations using my results and it worked perfectly !
I don't know what was wrong but now I don't have any problem.
Thank you for your answers !
Have a good day !
Regards Dimitri Hamelin
Viewing 5 reply threads- The topic ‘Update failed for solution component in static structural. Unable to update solution.’ is closed to new replies.
5069
1770
1387
1248
