March 7, 2019 at 4:33 pm
Bijoy Prasad
SubscriberHello,
I am trying to simulate steady flow around a hull model with 3 DoF (surging, heaving and pitching) in calm water. I used tetrahedral grid only around the hull and hexahedral grid rest of the domain. So I used Smoothing and Remeshing method with Six DOF option in dynamic mesh setting. I faced Update-Dynamic-Mesh failed. Negative cell volume detected after some time steps. Please help me to solve the problem, if possible please also check the attached case and udf file.
Bijoy
March 8, 2019 at 7:20 am
Max4
SubscriberHi,
have you decrease the time step yet?
March 8, 2019 at 10:42 am
Forum ModeratorThanks Max. Also check how the mesh is set up: missing a surface/volume in the MDM panel can also turn the mesh inside out.
March 8, 2019 at 9:05 pm
Bijoy Prasad
SubscriberThanks for the comments. Actually I already tried almost everything after reading lots of comments in ANSYS student community and CFD online forum but still no improvements. So could you please check my case and udf file to solve the problem?
Here I upload udf file but I can not upload case file. Could you please also help me to upload the case file in any other way?
March 11, 2019 at 3:50 am
Keyur Kanade
Ansys Employeeas ansys employees we can not download attachments. also as support, we do not debug udfs.
you may need to insert some images. other forum members can pitch in.
with that said, please check quality before you start the run. the starting mesh quality should be good to proceed.
March 13, 2019 at 3:58 pm
Bijoy Prasad
SubscriberThanks for the response. Here I add the image of udf 3 DoF (surging, heaving and pitching), please check it.
March 14, 2019 at 4:34 am
Keyur Kanade
Ansys Employeecan you please reduce mass and check it. this may give less displacement and may avoid negative cells.
if you still get negative elements, then we will have to see smoth and remeshing controls.
March 14, 2019 at 5:09 pm
Bijoy Prasad
SubscriberI previously tried to reduce the mass but no improvement.
Here I add the images of smoothing and remeshing settings, please check.
March 14, 2019 at 5:11 pm
March 19, 2019 at 3:24 am
Keyur Kanade
Ansys Employeecan you please use spring method for smoothing.
use no. of iterations = 100
under remeshing, please use length scales given in 'mesh scale info'.
March 28, 2019 at 12:56 pm
Bijoy Prasad
SubscriberThanks for the comments. I tried spring method but still it shows error after 2 seconds. Do you have any idea how can I get the results for at least 5-6 seconds?
I also used mesh scale info for length scales previously.
March 29, 2019 at 7:23 am
Keyur Kanade
Ansys Employeeyou need to reduce your mesh movement so that it does not move too much to give negative cells. you may want to do it in your udf.
February 9, 2020 at 3:35 pm
esgiraldop
SubscriberHi Bijoy. I am trying to simulate exactly the same thing as you. I tried using dynamic mesh during months with no positive results. Now I am triying with overset mesh instead of moving deforming mesh but I am still coping with the negative volume cells. Did you find any solution already?
October 25, 2022 at 8:47 pm
George Mathew
Subscriber -
November 29, 2023 at 9:45 am
Cláudio Corrêa
SubscriberHello,
I’m trying to reproduce the flow around a mechanically controlled door tutorial ((846) Ansys Fluent: Flow Around A Mechanically Controlled Door. - YouTube) and my simulation crashed after a few seconds with the error message “Update-Dynamic-Mesh failed. Negative cell volume detected”.
Analysing the results in CFD-Post, the problem occurs in the valve movement because it literally enters the mesh.
How do I fix the error?
Attached is a picture of the movement of the valve.
- The topic ‘Update-Dynamic-Mesh failed. Negative cell volume detected’ is closed to new replies.
5874
1306
