March 19, 2025 at 4:54 pm
thomasrappaport
SubscriberHi everyone,
I’m a PhD student working on the diffusion of particles near a boat. Before I can study particle diffusion, I need to fully understand the flow topology around the ship. I’m currently performing a mesh independence study, but I’m encountering some issues with non-physical velocity values in front of the boat (see attached image).
Here are the details of my setup:
Flow Conditions:
- Inlet: Uniform velocity profile with U∞ = 5 m/s
- Top and Side Boundaries: Symmetry
- Bottom: A moving wall (moving in the same direction and at the same speed as the inlet velocity)
- Outlet: Pressure outlet with gauge pressure = 0
Solver and Discretization:
- Turbulence Model: k-ω SST
- Solver: Coupled
- Discretization Schemes: All set to 2nd order
- Convergence: Residuals decrease by approximately 4 orders of magnitude, which seems acceptable. However, global flow parameters (such as the drag coefficient and wall shear stress) oscillate around an average value and never fully settle.
Mesh Details:
- Mesh Type: Polyhedral
- Number of Cells: Approximately 15 million
- Boundary Layer: 15 inflation layers with the first layer height set to 3.5 mm
It appears that the highest velocities are observed near the walls and in regions with corners or high curvature. I have also tried enabling the corner correction option; however, I couldn’t find clear recommendations regarding the value of the associated constant, and it seems that the correction did not change the results significantly.
My question is:
What guidelines or recommendations can be provided to address the oscillatory convergence and the presence of non-physical velocities, particularly in these high-curvature or corner regions? Any advice on adjustments to the mesh, solver settings, or boundary conditions would be greatly appreciated.Â
Thank you!
March 20, 2025 at 11:32 am
Forum ModeratorWhy would particles diffuse? Can you plot some contours on planar surfaces to show what's going on with the flow?Â
March 20, 2025 at 12:52 pm
thomasrappaport
SubscriberHi rob thanks for the reply.
I’d like to clarify a mistake in my previous post—I mistakenly mentioned "particle diffusion" when I actually meant "particle dispersion." My PhD work is focused on simulating the dispersion of particles on and around the boat to create a concentration map. However, before introducing particles into the simulation, it’s crucial to first understand the flow topology around the boat.
What kind of contour do you have in mind ? Velocity Magnitude, Pressure, TKE ?ÂThanks for the help
March 20, 2025 at 1:18 pm
Forum ModeratorOK, thanks, that makes more sense. Velocity magnitude would be good. Pressure on the hull may also be useful as you're looking for separation effects.Â
March 20, 2025 at 3:16 pm
March 20, 2025 at 3:25 pm
Forum ModeratorThat looks OK, if you replot with node values off you can judge if the mesh is fine enough in the regions of high gradients.Â
For oscillating results use residuals to check bulk convergence and point monitors to understand the fluctuations and whether they're significant.Â
March 20, 2025 at 5:15 pm
thomasrappaport
SubscriberWhat I'm truly questionning as I said in my first post are the physical values. My velocity inlet speed is 5 m/s, and I've a maximum speed that can go up to 9.72 m/s, so almost double. I don't see any reasons for such acceleration. In the litterature i've seen acceleration of 30% but not above. If I look at my y+ it varies between 0.164 and 183, I've read in the RANS Turbulence Modeling Best practice 2019 of F.Menter that k-w SST is insensitive to y+. I was wondering if that's really true ? It seems that problematic zones (with high speed) are corner near the bow and have y+ that range from 40 to 60
March 21, 2025 at 9:53 am
Forum ModeratorYou've also not plotted to show if the result is a mesh effect, contour smoothing or an overly constrained flow. How much space is there around the hull, and what is the % blockage factor of the boat onto the inlet? Look for "Projected Area".
Separately k-w does need a well resolved near wall mesh to benefit from the various schemes, otherwise k-e with Enhanced Wall Treatment is an option. y+ just means the cell next to the wall is at a height to capture stuff, it's also easy to monitor so everyone gets fixated on that value: how deep the inflation layer is, cell aspect ratio and cell growth rate are also very important but not necessarily as easy to check with a single number.Â
March 21, 2025 at 10:47 am
thomasrappaport
SubscriberThe blockage factor is 0.076%, calculated using the boat’s projected frontal area of 60.1471 m² relative to a domain measuring 540 m in width and 145 m in height. Since the boat is centered, there is approximately 210 m of clearance on each side of the domain.
For the inflation layers, I have implemented 15 layers, with the first layer set at a height of 3.5 mm. Regarding the mesh quality, the minimum orthogonal quality is 0.1, the average is 0.87, and the maximum is 1. The aspect ratio ranges from a minimum of 1.32 to an average of 8.1, with a maximum of 257.28.
Concerning the cell growth rate, I’m not entirely sure how to interpret the size change metric, but the values are as follows: a minimum of 1.08, an average of 2.3, and a maximum of 951.283.
For the contour on the problematic zones :ÂÂ
Out of curiosity, if SST k-w still needs a good resolution, why is there an "insensitive y+ wall treatment" for k-w models ?
Thanks for any help given :) -
March 21, 2025 at 11:52 am
Forum ModeratorI think the y+ insensitive bit is similar to Enhanced Wall Treatment - in that if the mesh is sufficient one option is used, if it's not another is used. It'll be explained properly in the manual: as I typically cover multiphase y+ is less of a concern!Â
The flow looks sensible but have a think about how cell aspect ratio might effect the recirculation and separation effects.Â
March 21, 2025 at 3:44 pm
thomasrappaport
SubscriberSo if I understand correctly my maximum aspect ratio is too high ? What value should be sufficient ?
March 21, 2025 at 4:05 pm
Forum ModeratorIt's possibly too high. When flow is aligned with a surface inflation is an efficient way of resolving near wall gradients. When flow separates inflation meshing is just a load of high aspect ratio cells. Check the various guides for advice.Â
4602
1510
1386
1209
