July 5, 2020 at 2:36 pm
Praveen95
SubscriberDear Ansys Community,
/forum/forums/topic/boundary-condition-in-static-structural-analysis/
Previously a question was asked by me and Mr. Peter suggested a new idea which we can find in the above link.
Accordingly, I have sliced the outer part into three parts and used cylindrical coordinate system and selected 3 vertices and applied the displacement BC where, the radial direction is kept free and angular (theta) ie., y-direction is fixed and also, the normal Z direction is also fixed.Â
My simulation included two steps.
- Transient thermal analysis: where I applied convective BC with convection coefficient of 25 W/m^2 °C and temperature cycles in °C as 22 to 180 to -40 to 180 to -40 to 180 to -40 to 22.
- Static structural Analysis: The result from thermal analysis is later imported into the static structural and applied with displacement BC along the cylindrical CS as discussed in the link specified above.
Problems being faced:
- Unlikely deformation is obtained as shown in the figures below. figure1 indicates initial Geometry, figure2 indicates deformation at 180°C and figured indicates -40°C deformation.
- I am getting this warning
- Large deformation effects are active which may have invalidated some of your applied supports such as displacement, cylindrical, frictionless, or compression only. Refer to Troubleshooting in the Help System for more details.
My doubts:
- Should I turn off large deformation?
- Is it a problem with the tetrahedral meshing?
- Should I load more slowly with more number of steps?
- Is it a problem with the BC?
Please help
Thanks in advance
Best Regards
Praveen
July 5, 2020 at 7:20 pm
peteroznewman
Subscriber- Should I turn off large deformation?
No, absolutely not.
Probably not. Refine the mesh to half the element size and see if you get the same result.
Not if you achieved convergence, but double the number of substeps and see if you get the same result.
No, this is a kinematic mount. It provides a stress-free ground connection.
What is the Result Display Scale Factor? Please show the images at 1.0 (True Scale).
Why do you claim the deformed shape is unlikely. There is a metal spiral embedded inside the material so there is a complicated differential CTE expansion/contraction that is generating internal stress in the composite part.
Set the CTE for both materials to the same value and apply a uniform temperature load you will get a perfectly uniform expansion. This will confirm that the BC is working properly.
July 5, 2020 at 7:41 pm
Praveen95
SubscriberDear Peter
Currently, I was checking with other possible ways and hence I don't have the results now. I have kept for solving again. I will let you know about the pictures later with true scale 1.0. Currently, I can see 1.1e-4(Auto) in vertex box.
I claim the deformation is unlikely because, I have ran the same model with just static structural and without transient thermal analysis. I just have the thermal BC and same number of steps. There I didnot get this much high deformation. -
July 5, 2020 at 7:49 pm
Praveen95
SubscriberDear Peter, I will follow the above suggested points. Regarding the steps, I am currently using Program controlled. If I do it on my own, Ansys takes so long time to solve. So, I will see the mntr file of the previous solution and just set it manually by doubling the number of substeps. Yes Regarding the BC it is stress-free.
July 7, 2020 at 6:38 am
- The topic ‘Unlikely deformation in transient thermal stress problem’ is closed to new replies.
6750
1324
1087
