February 7, 2020 at 5:50 am
Gustavo294
SubscriberHello everyone!Â
I am simulating a tensile test in ansys 17.1, but I got an error every time I put a 0.25 mm size element in my mesh.
This is what it says:Â An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes.
I am going to attach the solver output, in case is necessary.
I thank you in advance.
February 7, 2020 at 9:53 am
Aniket Chavan
Forum ModeratorAnsys staff can not download the files from the student community, Open the file and search for "error" and "warning"Â
and copy then paste them in your reply.Â
-Aniket
February 7, 2020 at 11:52 am
Gustavo294
SubscriberHello. Thank you for the quick response.
This is what I found:
The model data was checked and warning messages were found.      Â
 Please review output or errors file (                 Â
 C:Usersgus_qAppDataLocalTempWB_LAPTOP-7LITBE7E_gus_q_8024_5_ProjÂ
 jectScratchScr29DCfile0.err ) for these warning messages.
 *** ERROR ***              CP =   228.156  TIME= 00:45:29
 There is not enough memory for the Distributed Sparse Matrix Solver to Â
 proceed using the out-of-core memory mode. The total memory required Â
 by all processes = 22824 MB. The total physical memory that is    Â
 available on the system = 7707 MB. Please decrease the model size, or Â
 run this model on another system with more physical memory.
 *** WARNING ***             CP =   10.312  TIME= 00:41:17
 Element shape checking is currently inactive. Issue SHPP,ON or    Â
 SHPP,WARN to reactivate, if desired.
 *** WARNING ***             CP =   10.000  TIME= 00:41:17
 Using 1 iteration per substep may result in unconverged solutions for Â
 nonlinear analysis and the program may not indicate divergence in this Â
 case. Check your results.Â
February 7, 2020 at 3:59 pm
parkersheaffer
 proceed using the out-of-core memory mode.Â
Clear some space on your hard drive. see below
February 7, 2020 at 4:13 pm
peteroznewman
SubscriberI think this error is referring to RAM memory. In that case, reduce the number of elements in the mesh, or install more RAM. It might also help if the computer is Restarted to remove other programs from memory before starting the solver.
February 7, 2020 at 5:46 pm
parkersheaffer
SubscriberYou are right on the RAM, I made a mistake when skimming over it and missed the physical memory part.
February 11, 2020 at 3:42 pm
MuhammadDanish457
Subscriberhey! i am facing a similar error in the solution of non-linear analysis of a masonry structure. the following error is being displayed.Â
 *** ERROR ***   SUPPRESSED MESSAGE  CP =   84.062  TIME= 20:27:43
 The model data was checked and there were errors found.        Â
 Please check output or errors file.Â
kindly help me out if you know. thanking you in advance.Â
- The topic ‘Unknown error in Static Structural’ is closed to new replies.
5834
