July 13, 2024 at 4:29 am
Kim Sang Hoon
SubscriberI conflicted a error message, which is " The step data was checked and warning messages were found. Â Â Â Â Â Â Â
 Please review output or errors file (                 Â
 C:\Users\Owner\AppData\Local\Temp\WB_Owner_15776_2\_ProjectScratch\Scr4Â
 41B7\file0.err ) for these warning messages. "then, I saw Solver Output and I could see the three messages such as below.
1) " The model data was checked and warning messages were found. Â Â Â Â Â Â Â
 41B7\file0.err ) for these warning messages.  "Â
2) "The step data was checked and warning messages were found. Â Â Â Â Â Â Â
3) "ERROR: Worker process(es) with rank(s) 1 have encountered a FATAL error.
 The information below was gathered from the file*.out output file(s).
 Please review the worker process output file(s) listed below for more
 details on this error."Â
I think these errors are related to the path of files. So I made a new folder, new model, new workbench.
But well.. It was same. So what do you recommend? What should I do? Can you help me, sir?
July 15, 2024 at 10:49 am
Forum ModeratorWhat software is failing? Have you looked in the error files, what do they tell you?
July 15, 2024 at 11:58 am
Kim Sang Hoon
SubscriberI used 'steady-state thermal' in Ansys Workbench.Â
I tried to find the files but I couldn't. The files were not found. I found the similar files, but the files were empty.....
July 16, 2024 at 8:38 am
Forum ModeratorOK, so one for the Mech users.Â
July 16, 2024 at 11:00 am
Ashish Khemka
Forum ModeratorHello Kim,
Can you check the exact error from the .err and .out file?
Ashish Khemka
July 18, 2024 at 12:51 am
Kim Sang Hoon
SubscriberHello Khemka, Oh I found that. I've searched .err and .out, then finally I could find the files. Thanks! So what should I do from now on?
July 18, 2024 at 1:50 am
Ashish Khemka
Forum ModeratorHi Kim,
Can you please open those files in notepad and share the snapshots of error message you see?
Ashish Khemka
July 18, 2024 at 9:12 am
Kim Sang Hoon
SubscriberHi, Thanks for your help.
I opend the .err files and I found the messeage such as
/COM,ANSYS RELEASE 2024 R1 Â Â Â Â Â BUILD 24.1 Â Â Â UP20231106 Â Â Â 12:00:31
 *** WARNING ***             CP =   217.641  TIME= 12:02:55
 Element shape checking is currently inactive.  Issue SHPP,ON or     Â
 SHPP,WARN to reactivate, if desired.                  Â *** WARNING ***             CP =   349.125  TIME= 12:03:55
 Material number 160 (used by element 25617130) should normally have at Â
 least one MP or one TB type command associated with it.  Output of   Â
 energy by material may not be available.                "Â
And I opend the .out files and I found a lot of message such as
:Â "
 *** NOTE ***               CP =   1192.281  TIME= 12:16:46
 Symmetric Deformable- deformable contact pair identified by real    Â
 constant set 158 and contact element type 158 has been set up.  The   Â
 companion pair has real constant set ID 159.  Both pairs should have  Â
 the same behavior.                           Â
 MAPDL will keep the current pair and deactivate its companion pair,   Â
 resulting in asymmetric contact.                    Â
 Pure thermal contact is activated.
 The emissivity is defined through the material property.
 Thermal convection coefficient, environment temperature, and
 heat flux are defined using the SFE command.
 Target temperature is used for convection/radiation calculation
 for near field contact.
 Small sliding logic is assumed
 Contact detection at: Gauss integration point
 Average contact surface length         1.0670  Â
 Average contact pair depth          0.76337  Â
 Average target surface length         1.6093  Â
 Default pinball region factor PINB      0.25000  Â
 The resulting pinball region         0.19084  Â
 Initial penetration/gap is excluded.
 Bonded contact (always) is defined.
 Thermal contact conductance coef. TCC     4041.3  Â
 Heat radiation is excluded. *** NOTE ***               CP =   1192.281  TIME= 12:16:46
 Max.  Initial penetration 5.374761241E-07 was detected between contact Â
 element 25540342 and target element 25604619.              Â
 Â *** NOTE ***               CP =   1192.281  TIME= 12:16:46
 constant set 159 and contact element type 158 has been set up.  The   Â
 companion pair has real constant set ID 158.  Both pairs should have  Â
 MAPDL will deactivate the current pair and keep its companion pair,   Â
 Average contact surface length         1.6160  Â
 Average contact pair depth          0.48480  Â
 Average target surface length         1.0608  Â
 The resulting pinball region         0.12120  Â
 Heat radiation is excluded."Â
And terminal messages wereÂ
: "ERROR: Worker process(es) with rank(s) 2, 3 have encountered a FATAL error.
 Worker Process Output File .\file2.out:
 *** FATAL ***              CP =   111.094  TIME= 12:19:52
 This model requires more scratch space than available.  The program hasÂ
 currently allocated 12252 MB and was not able to allocate enough    Â
 additional memory in order to proceed.  Please increase the virtual   Â
 memory on your system and/or increase the work space memory and rerun  Â
 the program.  Problem terminated.                    Â
 Worker Process Output File .\file3.out:
 *** FATAL ***              CP =   111.062  TIME= 12:19:52
 currently allocated 11963 MB and was not able to allocate enough    Â
 the program.  Problem terminated. "ÂÂ
plz help me, sir..
July 18, 2024 at 1:13 pm
Ashish Khemka
Forum ModeratorHi,
The error message indicates that the model requires more scratch space. You can try changing the location of temporary files. Please see if the following link helps:
How to change the location of disk where temporary files are written? - Ansys Knowledge
Ashish Khemka
- The topic ‘unknonw error occured .. plz help me’ is closed to new replies.
5654
1890
1414
1303
