September 9, 2024 at 3:41 pm
p20230481
SubscriberWhen I am making a Geometry in Pre Post, what are the units assumed by the software? mm/ m / inches ?
And what units are assumed for force and speed etc?
September 10, 2024 at 1:51 pm
Alex Rycman
Ansys EmployeeHello,Â
LS-DYNA mandates the use of a consistent set of units i.e., it is up to the users to choose a unit system and be consistent with it.Â
E.g., if a user decides that length is mm, time is a ms, and mass is kg than kN, GPa etc.ÂPlease see: Consistent units — Welcome to the LS-DYNA support site
Thank you,
AlexÂ
ÂÂ
September 11, 2024 at 5:35 am
p20230481
SubscriberHi,
Thank you.
Could you please suggest me which model I could use to introduce shock wave inside shock tube? Task of this shock wave will be to do forming of sheet metal inside shock tube.
Remember that this shock wave is not produced by a blast, rather inside a shock tube due to high pressure diffrence between the two chambers of the shock tube.
5719
