October 7, 2020 at 1:41 am
ssagar
SubscriberHi,
I am performing the Charpy Impact test on a Nickel Based Superalloy Inconel 718. I used SPH Form 0 initially in LS-DYNA however, the specimen fractured based on tensile instability. So I decided to use Form 12 which is expected to take care of Tensile Instability.
Using Form 0, there is no penetration of the 5 m/s striker, however with the Form 12, the striker is going through the specimen.
Can you kindly indicate where I am going wrong. The picture shows the difference.
Thank you,
S
October 8, 2020 at 4:36 pmChris Quan
Ansys EmployeeMake sure the material model of the Nickle Alloy has damage or failure criterion. If not, use *Mat_Add_Erosion to add material failure model to the Nickle so its material strength will not be over-predicted. nJanuary 22, 2021 at 3:35 amssagar
SubscriberThank you very much. I used the Johnson Cook Failure CriterianViewing 2 reply threads- The topic ‘Unexpected penetration of striker (Charpy Test) in SPH Form 12 Specimen – LS-DYNA’ is closed to new replies.
6495
