January 31, 2023 at 10:20 pmLiza GuntherSubscriber
Hi all,
I'm using HFSS to model the H field on a solid object. I've exported the H field as a .dsp file, and I'm struck trying to recreate the field map in python. I know the element solution gives the field values for the body, but I don't know how to differentiate the x, y, and z elements as they are all in one list. Does anyone know the format of the coordinates in a .dsp file?
Thanks in advance.
February 7, 2023 at 12:31 pmPraneethForum Moderator
Hi Liza,
Thank you for reaching out to us and we appreciate your patience.
Please provide more information to help us serve you better:
- Give the steps you have used to export the field in dsp format.
- Do you have to use the dsp format only?
Best regards,
Praneeth. -
September 25, 2023 at 4:45 pmZheng YangSubscriberHi Liza, I am dealing with similar problems. Did you get a good solution? Best regards, Zheng
February 7, 2023 at 12:35 pmPraneethForum Moderator
Hi Jakke,
It looks like your response is out of context of the original thread. Please check once.
Best regards,
Praneeth.
- The topic ‘Understanding H Field element solution’ is closed to new replies.
Ansys Innovation Space
- HFSS Incident Plane Wave excitement mode
- Simulation of capacitor combining eddy currents with displacement currents
- How to calculate eddy and hysteresis losses of the core?
- Ansys Maxwell 3D – eddy current
- How to determine initial position in motion setup
- dq graph non-conformity
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Parametrizing coil “terminals” with coil geometry
- On-chip inductor design
- Maxwell circuit – PWM
599
591
565
366
