May 24, 2018 at 4:31 am
Eng1989
SubscriberHiÂ
Currently i am facing an issue that when i am doing meshing check - an errors show that Un assigned Interface Zones as shown in below picture and archive attached. Due to Long geometry i have crated two faces for Fluid and three faces for the soil, i have defined these edges as interface.
Can you please advise how i can solve this issue
May 24, 2018 at 5:18 pm
May 24, 2018 at 9:24 pm
Eng1989
SubscriberThank you very much Rahul
I have removed these selection, But Fluent considered it as a wall and creat a shadow , do i need to change it as interior ?? .
Also, When i have setup my model and run the solution i am getting a floating point even my mesh is uniform and around 412 K . can you please advise ?
May 25, 2018 at 6:32 pm
raul.raghav
SubscriberI think i mentioned this before in another post of yours. You should reduce the size of the soil face in your geometry. Why do you need that big a soil face? And can't you reduce the length of the pipe thats buried in the ground? Such a slender geometry would be a difficult step to begin a simulation particularly with the different interfaces in the system. I'd suggest you to reduce the size of the pipe first and work on a simplified geometry before you try this geometry.Â
May 25, 2018 at 8:46 pm
Eng1989
SubscriberThank you Raul , i apprecaite your advise
The Point is , i am trying to validate an article having  the same pipe dimension and soil. i know that my issue is from the mesh and i have reduced the soil face, Before i used to do meshing by using a Proximity option on advanced sizing and i got a great result and no floating point showed while running the simulation, but the issue on this option i do not have any control on edge sizing " number of division ", so i used the adaptive option to have more control on number of division on every edge but with this option i am getting floating point on fluent.
Can you please advise any suggestion to have a control on the edges and keep the pipe and soil dimension same and run the simulation without any issue
Again thx Rahul appreciate your time.
May 26, 2018 at 3:45 pm
- The topic ‘Unassigned Interface Zones-Fluent 2D Issue’ is closed to new replies.
5834
