Ansys Free Student Software
Unable to use Workbench 2023 R2 of ANSYS 2023 Student
    • hollyfire1988
      I installed ANSYS 2023 Student. After opening Workbench, a warning interface will show up, causing me not be able to use the software at all (Mechanical, SpaceClaim, etc..). Not sure why, could someone help me out?
    • Rajeshwari Jadhav
      Hi Holly,
      Did you install the application as admin? If no then please install it as admin.
      Can you check your event logs goto START--> event viewer--> expand windows logs--> select Application log. Do you see an error logged over there?
      • hollyfire1988
        Yes, there are a bunch of errors, mainly about license acquisition failure.
        I did run the installation as an admin though...
  • The topic ‘Unable to use Workbench 2023 R2 of ANSYS 2023 Student’ is closed to new replies.
