Unable to use Gradient Limiter
    • ae22b001
      I am unable to use the Multidimensional gradient limiter with the density based solver (implicit).
      Are there any conditions for using it? Thanks
    • ae22b001
      Please assist me with this, Thanks
      Bumping after 8 hours isn't going to do anything, especially overnight.
      You're in the panel, what's the problem?
      • ae22b001
        The option to apply a limiter filter is greyed out. This doesn't happen for the standard and differentiable limiter
      Then it's likely not available for the solver settings.
    • ae22b001
      Any idea why? Nothing is mentioned about this in the fluent user manual
      No, but there are several models that aren't enabled in the Density Based Solver.
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v242/en/flu_ug/flu_ug_use_grad_limit.html
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v242/en/flu_th/flu_th_sec_grad_limit.html
Viewing 5 reply threads
