February 16, 2021 at 4:21 pm
db_ik
SubscriberFebruary 26, 2021 at 4:52 pmANSYS_MMadore
Forum ModeratorArrayWhat happens if you start Workbench using vglrun wb202 or vglrun wb211.nWhat do you have for graphics devices on the local and remote machines?nFebruary 28, 2021 at 8:16 amdb_ik
SubscriberHi, thank you for your replynthe command with n$ vglrun /ansys_inc/v211/Framework/bin/Linux64/runwb2 nshows the error as unable to start the meshing editor.nit works for Ansys 2020 R1 but after version 2020 R2 & 2021R1 show the error of unable to start the meshing editor.nFluent and design modeler are working find for all version, but for not the mesher.nI attached the glxinfo, you can see the graphics optionn(it has Nvidia Quardo K2000 - installed the most updated driver from Nvidia)nat front of the workstation desk, all version works fine however, remote access is the issue though version 2020R1 works all fine.nCould you please have a look why the version 2020R2 and 2021R1 are not working...nMany thank you,nMarch 1, 2021 at 12:37 pmANSYS_MMadore
Forum ModeratorCan you run these commands and send the output?.cat /etc/*releasenglxinfo -display :0 | grep -i opengl.versionnLIBGL_DEBUG=verbose glxgearsnLIBGL_DEBUG=verbose glxinfonlspci -vnn | grep VGA -A 12nnvidia-sminnvidia-settings -q NvidiaDriverVersionnnvidia-settings -q allnnMarch 2, 2021 at 9:56 pmdb_ik
SubscriberThank you for your help!nplease find attached files for the informationnnMarch 3, 2021 at 1:46 pmANSYS_MMadore
Forum Moderatorif you open a command prompt and run 'ping localhost' can you share the output?nMarch 3, 2021 at 2:32 pmdb_ik
SubscriberThank you for your prompt message, please see below information for 'ping localhost'n$ ping localhostnPING localhost (127.0.0.1) 56(84) bytes of data.n64 bytes from localhost (127.0.0.1): icmp_seq=1 ttl=64 time=0.056 msn64 bytes from localhost (127.0.0.1): icmp_seq=2 ttl=64 time=0.030 msn64 bytes from localhost (127.0.0.1): icmp_seq=3 ttl=64 time=0.019 msn64 bytes from localhost (127.0.0.1): icmp_seq=4 ttl=64 time=0.024 msn64 bytes from localhost (127.0.0.1): icmp_seq=5 ttl=64 time=0.024 msn^Cn--- localhost ping statistics ---n5 packets transmitted, 5 received, 0% packet loss, time 3999msnrtt min/avg/max/mdev = 0.019/0.030/0.056/0.014 msnMarch 4, 2021 at 1:42 pmANSYS_MMadore
Forum ModeratorArray RH 7.5 is not supported for ANSYS 2021 R1. When you installed 2021 R1 it may have changed something in the ANSYS files that is affecting ANSYS 2020 R2. It's most likely related to the libs since it mentions libstdc++.so.6.nThe LD_LIBRARY_PATH=/ansys_inc/v211/Framework/bin/Linux64/Mesa#export is set to 2021 R1. Can you delete this or set to the 2020 R2 and see if this resolves the problem for 2020 R2 since it is supported under this OS and, if so, you will not be able to run 2021 R1 on this machine without updating the OS. nMarch 4, 2021 at 9:24 pmdb_ik
SubscriberThank you for your comment, I applied as you recommanded but the version 2020R2 is also not working.nAt the physical workstation location, all versions are working okay, but remote access causes the issue.non another machine, fresh restarted the OS and cleared the caches by deleting .ansysnit starts the mesh editor ONLY ONE TIME with following statement as[Info] Server started at ws://0.0.0.0:0 (actual port 44911)nHowever, fails to start the mesh editor no the next opening mesh.nRegards,March 5, 2021 at 1:29 pmANSYS_MMadore
Forum ModeratorWhat is the version of VNC you're using? Are you using VNC Connect 6.7.2 and VirtualGL 2.6?nhttps://www.ansys.com/-/media/ansys/corporate/files/pdf/solutions/it-professionals/platform-support/remote-display-and-virtual-desktop-support-2021-r1.pdf?la=en&hash=A0A10CB1AD545ACBEC69B57DCE129E5540E7E63CnnMarch 8, 2021 at 2:44 pmdb_ik
SubscriberIt is now updated RHEL 7.5 to 7.7 remotely.nIt is using TigerVNC server, not Real VNC.nAfter the update of RHEL, the design modeller and mesher can not start and error message is;n[VGL] ERROR:Could not open display :1.0.n   Error:SERVER TO CLIENT CONNECTION ERROR:Connection to WB failed:System.ArgumentException: Invalid port number 0 upon calling CreatePortBasedURIn at Ans.IPC.Remoting.Common.Connection.CreatePortBasedURI (System.Int32 portNumber, System.Type requestedType) [0x00023] in <46baf23f153a45738c126797ab4c5b9b>:0 n at Ans.IPC.Remoting.Server.ServerToClientConnection.InitialConnect (System.Type classToProxy) [0x00000] in <46baf23f153a45738c126797ab4c5b9b>:0 n at Ans.IPC.Remoting.Server.ServerToClientConnection.TryToConnect () [0x00000] in <46baf23f153a45738c126797ab4c5b9b>:0for the display, vglrun -d:1.0 glxgears is perfactly working and run ansys as vglrun -d :1.0 wb211 showed above error.nViewing 10 reply threads- The topic ‘Unable to start the Meshing editor – Linux (RHEL 7.5) VNC VirtualGL’ is closed to new replies.
6660
1313
