March 31, 2020 at 5:14 pm
palashacharya2
SubscriberI am currently using a Linux system (on the university supercomputer) to run ANSYS Mechanical (v20.1). However, when I try clicking on geometry or model it is unable to start mechanical editor or design modeler. I have tried reinstalling the software but to no avail. While I referred to some previous threads which suggest renaming a folder in %appdata%, I am unsure as to how to proceed in a Linux based system.
April 1, 2020 at 12:39 am
tsiriaks
Ansys EmployeeThis is likely a graphics issue, so resetting the 'appdata' will not help.
Is there any visualization node with good graphics card installed/setup on this cluster ? Here is the list of supported/tested graphics cards
https://www.ansys.com/-/media/ansys/corporate/files/pdf/solutions/it-professionals/platform-support/graphical-display-graphics-cards-tested-2020-r1.pdf?la=en&hash=6FAC80890F2CFFD6B74DE7B3361ABA7AE96B035C
If there is no node with good graphics, you can try software rendering mode but I can't guarantee that it will help
export LIBGL_ALWAYS_INDIRECT=1
export LIBGL_ALWAYS_SOFTWARE=1
export LD_LIBRARY_PATH=
/ansys_inc/v201/Framework/bin/Linux64/Mesa
/ansys_inc/v201/Framework/bin/Linux64/runwb2 -oglmesa
If this still doesn't work, you will have to do pre/post processing on a laptop, ideally with graphics card, then just use the cluster for solving (but need to use batch command to submit the jobs)
April 7, 2020 at 11:23 pm
palashacharya2
SubscriberThank you very much for your suggestion. I tried using the software rendering mode but it didn't work. Do you happen to have a reference for how the code for submitting the jobs in batch mode for clusters would look like for ANSYS Mechanical? Â
April 10, 2020 at 10:57 pm
tsiriaks
Ansys EmployeeYou can refer to the batch command from Chapter 4 of this guide
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_dan/dan_config.html
but it can't tell you exact command for your cluster submission because there are various job schedulers and each cluster setup is different depending on how your admin set it up. So, I would recommend to consult with your cluster admin on cluster submission command , then incorporate that with ANSYS batch solve command from the guide above.
April 13, 2020 at 11:44 pm
April 15, 2020 at 11:13 pm
tsiriaks
Ansys EmployeeWelcome ! Glad to hear it helps. Please mark the thread as 'Is Solution' so others know that this has been addressed
- The topic ‘Unable to start Mechanical Editor in Linux system’ is closed to new replies.
6660
1313
