December 1, 2022 at 10:49 am
Carlo Mingioni
SubscriberHi, I'm using an academic license for Anys 2022 R2. I can start workbench, spaceclaim, mechanical, cfx and so on. But when I try to run fluent from a fluidflow block, it opens a window in fluent displaying the following.
Unable to connect to external socket: Error during socket creation
Opening output file:"SolutionResult.xml"
Welcome to ANSYS Fluent 2022 R2
Copyright 1987-2022 ANSYS, Inc. All Rights Reserved.
Unauthorized use, distribution or duplication is prohibited.
This product is subject to U.S. laws governing export and re-export.
For full Legal Notice, see documentation.
Build Time: Nov 10 2022 18:40:13 EDT Build Id: 10213
Connected License Server List: 1055@ansys.infn.it
Info: Your license enables 4-way parallel execution.
For faster simulations, please start the application with the appropriate parallel options.
This is an academic version of ANSYS FLUENT. Usage of this product
license is limited to the terms and conditions specified in your ANSYS
license form, additional terms section.
Host spawning Node 0 on machine "LAPTOP-TLGT943O" (win64).
ID Hostname Core O.S. PID Vendor
n0 LAPTOP-TLGT943O 1/16 Windows-x64 3716 AMD Ryzen 7 PRO 5850U with Radeon Graphics
host LAPTOP-TLGT943O Windows-x64 14564 AMD Ryzen 7 PRO 5850U with Radeon Graphics
MPI Option Selected: intel
Cleanup script file is C:\Users\mingioni\cleanup-fluent-LAPTOP-TLGT943O-14564.bat
No error handler available
Error: Cortex received a fatal signal (SEGMENTATION VIOLATION).
Error Object: ()"
I know someone suggests to launch fluent outside workbench but I need to get it done in the integrated environment. What could be the cause of this?
Thanks.
December 6, 2022 at 9:47 am
V.P
Ansys EmployeeHi Carlo,
Try running after turning off your firewall and virus scanner.
December 6, 2022 at 9:58 am
Carlo Mingioni
SubscriberAlready done, nothing. It's not the problem.
November 10, 2023 at 9:53 am
departamento.informatica
SubscriberDid you solve this problem? I have the same behaviour in some laptops
November 10, 2023 at 10:04 am
SubscriberI reply to myself, just solved the problem. It occurs when more than 1 network connection is working, for example ethernet and wifi, just disable the wifi or unplug the cable and it works.
- The topic ‘Unable to start Fluent’ is closed to new replies.
5694
1891
1419
