July 8, 2024 at 4:47 pm
jgna
SubscriberHello. I'm encountering an error while saving an animation.
Writing Video...
"mpeg_encode param10"
MPEG ENCODER STATS (1.5b)
TIME STARTED: Tue Jul 09 00:42:02 2024 MACHINE: unknown FIRST FILE: D:\Project\NewFolder/animation-1_15_0000.ppm LAST FILE: D:\Project\NewFolder/animation-1_15_0036.ppm PATTERN: i GOP_SIZE: 12 SLICES PER FRAME: 1 RANGE: +/-8 PIXEL SEARCH: FULL PSEARCH: EXHAUSTIVE BSEARCH: CROSS2 QSCALE: 8 8 8 REFERENCE FRAME: ORIGINAL
Input file too small! (????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????(?) Removing frame files ... done.
Done.
I get this error and the animation doesn't save. I have already tried the solutions I found elsewhere, such as loading the animation cxa and hsf files in Fluent with nothing else open, but I still get the same error.
I found the solution. (https://innovationspace.ansys.com/forum/forums/topic/input-file-too-small-animation-error-in-fluent/)Â To resolve the error, try lowering the display resolution.
In the link, user encountered the same error while using the 2023 version. Currently, I'm experiencing the same issue with the 2024 version. Please address this error in the next update. -
July 9, 2024 at 1:39 pm
Nilay Pedram
Forum ModeratorHello,
Thanks for pointing this out. We will look into this.
- The topic ‘Unable to Save Animation in Video (Input file too small! error)’ is closed to new replies.
4607
1510
1386
1209
