September 3, 2021 at 2:45 am
Priya_pandit
SubscriberHello, I am unable to install new ansys student version 2021 r2, I am getting error can anyone please check and help me
Start Installation: Fri Sep 3 07:49:27 2021
Revision: 2021 R2
Platform specifics:
  Windows
Username of Installer: DESKTOP-0RJG7NLHP
User Has Administrator Privileges
C:UsersHPAppDataLocalTempans_install_tmp2924instcore.exe -usetempdir C:UsersHPAppDataLocalTempans_install_tmp2924 -launchdir "F:Ansys main file" -admin
Initial mount directory:
  F:Ansys main file
Installation Directory:
  C:Program FilesANSYS IncANSYS Student
Windows x64
     EnSight
Date verification complete...No conflicts found.
The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
This may take a while ...
Successfully copied prerequisites from media.
You don't need to install any prerequisites.
Reading the installation media contents - please wait.
 Extraction: F:Ansys main fileinstcore clCOMMON.TGZ ...
 Extraction: F:Ansys main fileinstcore clWINX64.TGZ ...
 Extraction: F:Ansys main filestudentWINX64.7z ...
 Extraction: F:Ansys main filelicenseWINX64.7z ...
RSS is disabled
Performing licensing configuration via the following command...
  "C:Program FilesANSYS IncANSYS StudentShared Filesinwinx64 clsh.exe" "C:Program FilesANSYS IncANSYS StudentShared FilesLicensinglicadminscriptsLicAdminMain.itcl" -silentinstallclient -release "2021 R2" -lang en-usÂ
Licensing configuration has completed.
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigCommon.exe
Configuring ANSYS TurboGrid ...
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigTG.exe
Creating Start Menu items for Ansys client licensing ...
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigWB.exe
Running "C:Program FilesANSYS IncANSYS Studentv212RSMinAnsConfigRSM.exe" -encodingUTF8
Configuring RSM...
Configuring default RSM and ARC Port numbers for 2021 R2 ...
Done!
User has Administrator privileges
Creating Start Menu Shortcut for RSM 2021 R2 Configuration...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsAnsys 2021 R2Remote Solve ManagerRSM Configuration 2021 R2.lnk
Creating Start Menu Shortcut for RSM 2021 R2 Job Monitor...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsAnsys 2021 R2Remote Solve ManagerRSM Job Monitoring 2021 R2.lnk
Creating Start Menu Shortcut for RSM 2021 R2 Cluster Monitor...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsAnsys 2021 R2Remote Solve ManagerRSM Cluster Monitoring 2021 R2.lnk
Creating Start Menu Shortcut for ARC 2021 R2 Configuration...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsAnsys 2021 R2Remote Solve ManagerARC Configuration 2021 R2.lnk
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigANSYS.exe
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigAQWA.exe
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigCFX.exe
Configuring ANSYS Viewer ...
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigSpaceClaim.exe
Configuring ACP ...
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigACP.exe
Configuring Help ...
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigHelp.exe
ANSYS Internet Doc has been configured.
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigCHEMKIN.exe
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigFORTE.exe
Configuring EnSight ...
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigEnsight.exe
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigFENSAP.exe
Running "C:Program FilesANSYS IncANSYS Studentv212aisol..commonfilesCADinwinx64Ans.CadInt.CADConfigurationUtility.exe"
Log files is C:Program FilesANSYS IncANSYS Studentv212CADConfigLogsLatestCADConfigurationMgr.log
MessageLogger.logFilePath is C:Program FilesANSYS IncANSYS Studentv212CADConfigLogsLatestCADConfigurationMgr.log
ErrorLogger.errorFilePath is C:Program FilesANSYS IncANSYS Studentv212CADConfigLogsCADConfigurationMgr.err
Prerequisites ..... Configure Success
SC Workbench PlugIn ..... Not Configured
Discovery Workbench Plugin ..... Not Configured
Successfully created file associations.
The installation completed with warnings/errors. Review any .err or .log files in:
Installation Complete: Fri Sep 3 07:51:04 2021
September 15, 2021 at 1:58 pmGeorge Karnos
Ansys EmployeeWhat is the contents of the install.err file located under:
C:\Program Files\ANSYS Inc\ANSYS Student
Viewing 1 reply thread- The topic ‘Unable to install new ansys student version 2021r2’ is closed to new replies.
5824
