April 25, 2024 at 5:04 am
shubham.chavan
SubscriberHello Team,
We are working on a DC machine with series wound field coils, and getting Error in RMxprt as - While parsing expression: "infA", an error was found near character 3. 'infA' is not a defined variable name in this context.
Also, I would like to know more about the template option "Compound Exciting mode" , as my machine is simply DC Series motor, so what is the need of this option.
 Thanks & Regards,
Shubham Chavan
May 3, 2024 at 2:56 am
HDLI
Ansys EmployeeHello Shubham,
   I am not sure why your question is not same with the content. For compound exciting, please review Maxwell help manual. The cumulative exciting or differential exciting of the series winding to the shunt winding of DC motor. Select Cumulative or Differential from the drop-down list.Â
   More additional informaiton that you could search and find: cumulative exciting or differential exciting.Â
HDLI
- The topic ‘Unable to create a Maxwell 3D model of a DC machine from RMxprt 2D.’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
4167
1487
1338
1188
