May 23, 2022 at 1:23 pm
shane.hesprich
SubscriberI can launch fluent no problem, and can verify that a license was checked out by viewing $HOME/.ansys/licdebug.FLUENT.211.out.
When I use the mapdl launcher I get the following error:
*** IMPORTANT LICENSING MESSAGE ***
ANSYS LICENSE MANAGER ERROR:
Could not connect to license server: 29007@127.0.0.1. System error: 111 "Connection refused".
 *** ERROR - ANSYS license not available.
When I check the $HOME/.ansys/ansyscl-.log I see the following error:
2022/05/20 11:54:30Â INFOÂ Â Â Â Â Â Â ANSYSLI_CMD=/usr/ansys_inc/v211/licensingclient/linx64/ansyscl -acl 36217.83209 -nodaemon -log /home//.ansys/ansyscl. .36217.83209.log
2022/05/20 11:54:30Â INFOÂ Â Â Â Â Â Â ANSYSLI_INITIALIZATION_FILE='/usr/ansys_inc/shared_files/licensing/ansyslmd.ini'
2022/05/20 11:54:30Â INFOÂ Â Â Â Â Â Â ANSYSLI_PRODORD_FILE='/usr/ansys_inc/shared_files/licensing/prodord/ansysli.prodord.xml'
2022/05/20 11:54:30Â INFOÂ Â Â Â Â Â Â ANSYSLI_TIMEOUT_FLEXLM=15
2022/05/20 11:54:30Â INFOÂ Â Â Â Â Â Â Configuring ACL Core
2022/05/20 11:54:30Â INFOÂ Â Â Â Â Â Â ACL Core Initialized
2022/05/20 11:54:30Â INFOÂ Â Â Â Â Â Â ANSYSCL_PORT=29007
2022/05/20 11:54:30Â INFOÂ Â Â Â Â Â Â Listen Socket Created
2022/05/20 11:54:30Â INFOÂ Â Â Â Â Â Â ANSYSLI_CLIENT_IDLE_TIMEOUT=0
2022/05/20 11:54:30Â INFOÂ Â Â Â Â Â Â ANSYSCL_FNP_PATH=1055@xx.xx.xx.xx
2022/05/20 11:54:30Â INFOÂ Â Â Â Â Â Â Ready to accept connections.
2022/05/20 11:54:31Â INFOÂ Â Â Â Â Â Â ANSYSLI_IP_OVERRIDE option is off.
2022/05/20 11:54:31Â HANDSHAKE_ERRORÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 11:127.0.0.1
       System error: 0 "".
2022/05/20 11:54:33Â INFOÂ Â Â Â Â Â Â License server shutdown is complete. Thank you.
The command ansysli_util -statli 2325@connects successfully. Additionally, ansysli_util -checkout ansys yields the following:
ansys OUT id=-SYSTEM-2984-199468 shared_info= -SYSTEM-2984-199469 is_sharable=yes server=2325@xx.xx.xx.xx is_academic=yes has_academic_logo=no max_h_elem=0 max_nodes=0 max_struct_nodes=0 max_faces=0 max_bodies=0 max_species=0 min_cell_size=0 max_depth=0
   Resolved by Feature: id=0 feature=ansys product=ANSYS Mechanical Enterprise
Any assistance would be appreciated. Additionally if you need any other information please let me know and I will get it posted. Thanks in advance!
May 25, 2022 at 12:45 pm
George Karnos
Ansys EmployeeTry running without firewall enabled.
If this works, is it possible to check the firewall logs to see what is being blocked.
May 31, 2022 at 2:55 pm
shane.hesprich
SubscriberThanks for the feedback Geo. I disabled the firewall and tried again with the same result. Additionally, I am fairly certain it is not a firewall issue since fluent works fine, and so does 'ansysli_util -checkout ansys'. If it was a firewall issue one would think it would inhibit all ANSYS software not just mapdl.
Also, I am unsure which feature mapdl checks out, so I just used ansys. If there is a specific feature(s) used by mapdl I could try using the ansysli_util to check out those specific features and make sure the server is servicing those features properly.
Any other tips would be appreciated. Thanks!
May 31, 2022 at 3:26 pm
George Karnos
What is the contents of the
$HOME/.ansys/licdebug.MECH.211.out file?
Also, can you post the output from the ansysli_util -statli 2325@command? remove the servername reference in the output
May 31, 2022 at 3:42 pm
shane.hesprich
SubscriberI do not have a licdebut.MECH.211.out. Here are the licdebug files I do have:
licdebug.ACT.211.out
licdebug.ALI_UTIL.202.out
licdebug.ALI_UTIL.211.out
licdebug.ANS_INFO.211.out
licdebug.ANS_WB.211.out
licdebug.FEAT_ANSYS.211.out
The output from the ansysli_util command is too long to be posted in the comment so I added it as an attachment.
Your help is most appreciated!
May 31, 2022 at 3:45 pm
George Karnos
Ansys EmployeeWhat is does the licdebug.FEAT_ANSYS.211.out file?
We are not permitted to open files. Please post contents.
May 31, 2022 at 4:02 pm
shane.hesprich
SubscriberThe log was too big, so I just included the contents from the most recent attempt.
2022/05/31 08:46:10INFOStarting Licensing Client Proxy server.
2022/05/31 08:46:10INFO/usr/ansys_inc/v211/licensingclient/linx64/ansyscl -acl 396472.4480 -nodaemon -log /home//.ansys/ansyscl. .396472.4480.log
2022/05/31 08:46:10INFOStarted ANSYSLI server.
2022/05/31 08:46:11HANDSHAKE_ERROR0/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
Could not make an SSL handshake with server 62561@127.0.0.1.
Could not read certificate file.
2022/05/31 08:46:11ERRORCould not make an SSL handshake with server 62561@127.0.0.1.
2022/05/31 08:46:13HANDSHAKE_ERROR0/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
System error: 104 "Connection reset by peer".
2022/05/31 08:46:13ERRORCould not make an SSL handshake with server 62561@127.0.0.1.
2022/05/31 08:46:14CONNECT_ERROR0/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
Could not connect to license server: 62561@127.0.0.1. System error: 111 "Connection refused".
2022/05/31 08:46:14ERRORCould not connect to license server: 62561@127.0.0.1. System error: 111 "Connection refused".
2022/05/31 08:46:15CONNECT_ERROR0/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
2022/05/31 08:46:15ERRORCould not connect to license server: 62561@127.0.0.1. System error: 111 "Connection refused".
2022/05/31 08:46:16CONNECT_ERROR0/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
2022/05/31 08:46:16ERRORCould not connect to license server: 62561@127.0.0.1. System error: 111 "Connection refused".
2022/05/31 08:46:17CONNECT_ERROR0/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
2022/05/31 08:46:17ERRORCould not connect to license server: 62561@127.0.0.1. System error: 111 "Connection refused".
2022/05/31 08:46:18CONNECT_ERROR0/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
2022/05/31 08:46:18ERRORCould not connect to license server: 62561@127.0.0.1. System error: 111 "Connection refused".
2022/05/31 08:46:19CONNECT_ERROR0/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
2022/05/31 08:46:19ERRORCould not connect to license server: 62561@127.0.0.1. System error: 111 "Connection refused".
2022/05/31 08:46:20CONNECT_ERROR0/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
2022/05/31 08:46:20ERRORCould not connect to license server: 62561@127.0.0.1. System error: 111 "Connection refused".
2022/05/31 08:46:21CONNECT_ERROR0/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
2022/05/31 08:46:21ERRORCould not connect to license server: 62561@127.0.0.1. System error: 111 "Connection refused".
2022/05/31 08:46:22CONNECT_ERROR0/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
2022/05/31 08:46:22ERRORCould not connect to license server: 62561@127.0.0.1. System error: 111 "Connection refused".
2022/05/31 08:46:23CONNECT_ERROR0/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
2022/05/31 08:46:23ERRORCould not connect to license server: 62561@127.0.0.1. System error: 111 "Connection refused".
2022/05/31 08:46:24CONNECT_ERROR0/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
2022/05/31 08:46:24ERRORCould not connect to license server: 62561@127.0.0.1. System error: 111 "Connection refused".
2022/05/31 08:46:25CONNECT_ERROR0/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
2022/05/31 08:46:25ERRORCould not connect to license server: 62561@127.0.0.1. System error: 111 "Connection refused".
2022/05/31 08:46:26CONNECT_ERROR163610/0/0/0396472:FEAT_ANSYS:@ :linx640:xx.xx.xx.xx
May 31, 2022 at 4:11 pm
shane.hesprich
SubscriberIn case it helps at all this is the output from licdebug.FLUENT.211.out:
2022/05/20 10:23:18INFOStarting Licensing Client Proxy server.
2022/05/20 10:23:18INFO/usr/ansys_inc/v211/licensingclient/linx64/ansyscl -acl 32010.75728 -nodaemon -log /home//.ansys/ansyscl. .32010.75728.log
2022/05/20 10:23:18INFOStarted ANSYSLI server.
2022/05/20 10:23:20CLIENT_CONNECT1/1/1/132010:FLUENT:@ :linx647:xx.xx.xx.xx
2022/05/20 10:23:20NEW_CONNECTIONConnected to Licensing Client Proxy server: 14227@127.0.0.1.
2022/05/20 10:23:20CHECKOUTcfd_solve_level221.1 (2020.1029)1/1/1/501/1/1/132010:FLUENT:@ :linx647:xx.xx.xx.xx
2022/05/20 10:23:20CHECKOUTcfd_solve_level121.1 (2020.1029)1/1/1/501/1/1/132010:FLUENT:@ :linx647:xx.xx.xx.xx
2022/05/20 10:23:20CHECKOUTcfd_base21.1 (2020.1029)1/1/1/501/1/1/132010:FLUENT:@ :linx647:xx.xx.xx.xx
2022/05/20 10:23:20CHECKOUTFEAT_CFD_BASE21.1 (2020.1029)1/1/1/-11/1/1/132010:FLUENT:@ :linx647:xx.xx.xx.xx
2022/05/20 10:23:20CHECKOUTFEAT_CFD_SOLVE_LEVEL121.1 (2020.1029)1/1/1/11/1/1/132010:FLUENT:@ :linx647:xx.xx.xx.xx
2022/05/20 10:23:20CHECKOUTFEAT_CFD_SOLVE_LEVEL221.1 (2020.1029)1/1/1/11/1/1/132010:FLUENT:@ :linx647:xx.xx.xx.xx
May 31, 2022 at 4:30 pm
shane.hesprich
SubscriberI cleaned up ansysli_util so it will post:
Attempting to connect to ansysli_server running on 2325@...
Connection Established. Querying for additional information...
ANSYSLI_PORT = 2325
Hostname =
IP = xx.xx.xx.xx
Process Id = 2984
Full Version = 2.2.2 LM1 (20210125) for winx64. Updated at ANSYS Release 2021 R1.
Startup = NORMAL STARTUP 2022/03/17 03:21:38
Active Clients = 1
Max Clients = 5
Total Clients = 108458
WB Usage Tracking = ON
DP Reserve Support = ON
Monitor Status: Monitor Running
Monitor Version: ANSYS Licensing Interconnect version 2.2.1 (20210125) for winx64. Updated at ANSYS Release 2021 R1.
Licenses Cached for server:
FEATURECOUNTVERSIONEXPIRATION
1spacdes509999.9999 2022/07/06
1spacdes5009999.9999 2022/07/06
a_catv6_reader
a_catv6_reader
a_jt_reader
a_jt_reader
a_spaceclaim_catv5
a_spaceclaim_catv5
a_spaceclaim_dirmod
a_spaceclaim_dirmod
a_spaceclaim_faceteddata
acdi_adprepost
acdi_adprepost
acfd_vki
acfd_vki
acfx_bldmdlr
acfx_bldmdlr
acfx_pre
acfx_pre
acpreppost
acpreppost
advanced_meshing
advanced_meshing
afsp_gui
afsp_gui
afsp_optigrid
afsp_optigrid
afsp_viewmerical
afsp_viewmerical
agppi
agppi
alinks_gui
alinks_gui
am_module
am_module
am_prep
am_prep
am_print
am_print
ans_act
ans_act
anshpc
ansrom
ansrom
ansys
ansys
aqwa_pre
aqwa_pre
aqwa_solve
aqwa_solve
aspeos_fie
aspeos_fie
aspeos_hud
aspeos_hud
aspeos_level1
aspeos_level1
aspeos_level2
aspeos_level2
aspeos_level3
aspeos_level3
aspeos_opd
aspeos_opd
aspeos_ost
aspeos_ost
aspeos_solver
aspeos_solver
cfd_base
cfd_base
cfd_polyflow_ui
cfd_polyflow_ui
cfd_preppost
cfd_preppost
cfd_solve_level1
cfd_solve_level1
cfd_solve_level2
cfd_solve_level2
cfd_solve_level3
cfd_solve_level3
disco_level1
disco_level1
disco_level2
disco_level2
dsdxm
dsdxm
elec_filter
elec_filter
elec_solve_2d
elec_solve_2d
elec_solve_hfss
elec_solve_hfss
elec_solve_icepak
elec_solve_icepak
elec_solve_level1
elec_solve_level1
elec_solve_level2
elec_solve_level2
elec_solve_level3
elec_solve_level3
elec_solve_maxwell
elec_solve_maxwell
elec_solve_q3d
elec_solve_q3d
elec_solve_siwave
elec_solve_siwave
electronics2d_gui
electronics2d_gui
electronics3d_gui
electronics3d_gui
electronics_desktop
electronics_desktop
electronicsckt_gui
electronicsckt_gui
ema_charge_gui
ema_charge_gui
ema_charge_solve
ema_charge_solve
ema_gui
ema_gui
ema_solve
ema_solve
emag
emag
ensight_enterprise
ensight_enterprise
envision_pro
envision_pro
explicit_advanced
explicit_advanced
explicit_basic
explicit_basic
fluent_meshing
fluent_meshing
fluent_meshing_pro
fluent_meshing_pro
fluent_setup_post
fluent_setup_post
fluent_setup_post_pro
forte_3
forte_3
granta_edupack
granta_sim_mat_data
granta_sim_mat_data
ice_translator
ice_translator
mat_designer
mat_designer
motorcad
motorcad
motorcad_im
motorcad_im
motorcad_pm
motorcad_pm
motorcad_sync
motorcad_sync
nspice_apl
nspice_apl
nspice_hicap
nspice_hicap
nspice_sv
nspice_sv
optishpc
pemag
pemag
pexprt
pexprt
piautoin
piautoin
picatv5
picatv5
piproe
piproe
pisoledg
pisoledg
pisolwor
pisolwor
piug
piug
preppost
preppost
rd_ckcompute
rd_ckcompute
rd_ckgraph
rd_ckgraph
rd_ckpost
rd_ckpost
rd_ckpreproc
rd_ckpreproc
rd_ckui
rd_ckui
rd_fortemesh
rd_fortemesh
rd_forteui
rd_forteui
rd_forteviz
rd_forteviz
rd_kineticsapi
rd_kineticsapi
rd_mechforte
rd_mechforte
rd_mechmfc
rd_mechmfc
rd_mechsoot
rd_mechsoot
rd_mechwb
rd_mechwb
rd_reactionwbui
rd_reactionwbui
rdacis
rdacis
rdpara
rdpara
redhawk
redhawk
redhawk_apl
redhawk_apl
redhawk_caching
redhawk_caching
redhawk_gds2def
redhawk_gds2def
redhawk_inductance
redhawk_inductance
redhawk_lef2def
redhawk_lef2def
redhawk_mpr
redhawk_mpr
redhawk_netlisting
redhawk_netlisting
redhawk_passchk
redhawk_passchk
redhawk_pwrcalc
redhawk_pwrcalc
redhawk_sim0
redhawk_sim0
redhawk_sim1
redhawk_sim1
redhawk_sim3
redhawk_sim3
redhawk_spice_pkg
redhawk_spice_pkg
redhawk_vcd
redhawk_vcd
sherlock
sherlock
simplorer_advanced
simplorer_advanced
simplorer_control
simplorer_control
simplorer_cprogrinterface
simplorer_gui
simplorer_gui
simplorer_libsmps
simplorer_libsmps
simplorer_sim
simplorer_sim
simplorer_sim_entry
simplorer_sim_entry
simplorer_vhdlams
simplorer_vhdlams
siwave_level1
siwave_level1
sptartist
sptartist
sptdirectdotlib
sptdirectdotlib
sptgafsplit
sptgafsplit
spthdl
spthdl
sptipwizard
sptipwizard
sptmixedlanguage
sptmixedlanguage
sptmixedvt
sptmixedvt
sptmultipletestbenches
sptmultiplevoltages
sptmultiplevoltages
sptpowergating
sptpowergating
sptsoc
sptsoc
sptspefcapacitance
sptspefcapacitance
sptsynlib2alf
sptsynlib2alf
sptsystemverilog
sptsystemverilog
spttbengine
spttbengine
sptvectorless
sptvectorless
sptvectorselector
sptvectorselector
sptvwengine
sptvwengine
sptwsengine
sptwsengine
sptwwalflint
sptwwalflint
sptwwengine
sptwwengine
sptwwgaf
sptwwgaf
sptwwsim
sptwwsim
sptwwui
sptwwui
sptwwvcdplus
sptwwvcdplus
vmotion
vmotion
vmotion_catiai
vmotion_catiai
vmotion_drtrain
vmotion_drtrain
vmotion_drtrain_pre
vmotion_drtrain_pre
vmotion_links
vmotion_links
vmotion_mesh
vmotion_mesh
vmotion_mesh_pre
vmotion_mesh_pre
vmotion_para
vmotion_para
vmotion_post
vmotion_post
vmotion_pre
vmotion_pre
vmotion_step
vmotion_step
Viewing 8 reply threads
- The topic ‘Unable to check out license for mapdl using ANSYS 2021 R1 on RHEl 8’ is closed to new replies.
1311
