May 23, 2025 at 1:55 am
May 23, 2025 at 7:41 am
Atharv Joshi
Forum ModeratorHello,
I tried to reproduce the problem but it seems to work at my end. I don't see this error message.
This function is just trying to create co-incident constraint for the circle sketch drawn in line 188,189.
You can comment those lines and run the code it should create the geometry without co-incident constraint for circle.Regards
Atharv -
May 23, 2025 at 8:17 am
e1306841
SubscriberI tried that but it just showed an error in the next constraint line for the next circle. Then I tried commenting out all the constraint lines for the circles and then it showed an error for extrude further down. So I don't understand the issue really.
May 23, 2025 at 8:45 am
Atharv Joshi
Forum ModeratorWhat error do you see while extrduing the sketch?
Please check below course for learning more about scripting in SpaceClaim/Discovery and here's the help documentation link Scripting , Creating a Parameter Group
Scripting in Ansys Discovery | Ansys Innovation Courses
Advanced Scripting in Ansys Discovery | Ansys Innovation Courses
Regards
Atharv
3139
1007
923
858
792
