“Unable to attach geometry” when importing material properties from SolidWorks
    • GLP28
      Hi, whenever I try to import the material properties of a SW geometry, I get a message saying that SW crashed, followed by Ansys displaying a message saying "Unable to attach geometry"
      Is this an Ansys problem? Or a SW problem? I used to be able to import materials without problems, but now I get this error every the time.
      Apparently this problem is only happening with custom materials, still not sure if the problem is caused by SW or Ansys
    • 1shan
      Could you check - /forum/discussion/10593/unable-to-attach-spaceclaim-geometry. Also how do you import material properties from SW? Why cant you define them under engineering data?
      Regards Ishan.
  • The topic ‘“Unable to attach geometry” when importing material properties from SolidWorks’ is closed to new replies.
