UDF (VR_RATE)
    • parsaezzatjah71
      I am currently implementing a User-Defined Function (UDF) for a non-linear kinetic reaction as a volume reaction in Fluent. I have followed the guidelines provided in the documentation precisely. However, when I load the UDF in interpreted mode, the following error occurs. (the error and UDF are attached)
      I would greatly appreciate your assistance in identifying and resolving the issue, as it is critical for my project.
      Thank you for your time and support. Please let me know if you require any additional details or files to investigate this further.
      Use the built in compiler and then read all of the error and warning messages carefully.  Ansys staff will not be debugging code (not least as that'll break some of the legal requirements of helping on here), the wider community are welcome to.
