UDF to change particle integration step and print it
    • aniruddhabose96
      Hi
      I am using DEFINE_DPM_TIMESTEP to change the particle tracking time step following UDF manual, but when i am printing it using DEFINE_SCALAR_UPDATE, it is printing Fluents default time step value. What is the issue here? I have attached my UDF below.
      #include "udf.h"
      #include "dpm.h"
      DEFINE_DPM_TIMESTEP(my_dt,tp,dt)
          if(dt<0.001)
          {return 1;}
          return dt;
      }        /*UDF to check particle time step*/
      DEFINE_DPM_SCALAR_UPDATE(store_vel,c,t,initialize,tp)
          if (initialize)
              return;
              Message("part time step=%e\n",TP_DT(tp));
      I assume you hooked it up?
    • aniruddhabose96
      Yes like Function-compiled and then Build and load and then hooked it in respective area. It is printing Fluents default time step and not my given step.
      What did you set in the DPM panel?
