January 30, 2018 at 11:38 am
saadyw
SubscriberI have a 2D dynamic mesh case of a piston-cylinder arrangement as attached. I can create a udf to move the piston under certain velocity and the simulation proceeds with no problems.Â
What I need is to set the dynamic mesh zones according to a udf expressing the equation of motion of the piston which is :
a = (F + p1*A1 - p2*A2) / m  or if represented with velocity  dv = (F + p1*A1 - p2*A2) * dt / m
where: a .. acceleration, F .. External force, p1,p2 .. pressures on upper and lower piston boundaries respectively, A1,A2 .. areas at same locations and m .. mass of the piston.
I have got through a similar udf in the udf manual for equation of motion in x-dir, but I do not understand how the pressure forces are computed. So, IÂ want to know how the pressure on both sides is represented in the udf in my case.
This udf link is:Â https://www.cfd-online.com/Forums/fluent/87021-code-dynamic-meshing-udf.htmlÂ
Can you help me on this udf ?
- The topic ‘UDF for equation of motion’ is closed to new replies.
